Fuel Lines and fittings from tank...
Old Jul 22, 2002 | 11:07 AM
PrecisionH23a's Avatar
Default Fuel Lines and fittings from tank...
Yes ive done a search and this is pretty much last on my list. here is a pic of dustins set up... (dustin, i hope you dont mind me using your picture...)
I will be running -8an feed and -6an return. Can you tell me if these part #'s are right to run this?
<U> -8AN FEED</U>
-8an 90degree bulkhead adapter part #983308
summit shows part 983303 for this (i guess its an error on the website...):
the part should look like:
-8an bulkhead nut, part #?????
-8an straight swivel seal hose send, part # 800108
<U> -6an return </U> :
-6an 90degree bulkhead adapter part #983306
-6an bulkhead nut, part #592406
-6an straight swivel seal hose end, part #800106
Also, is this correct?
for fuel return it goes from FPR outlet to the Fuel return fitting at the tank?
for fuel feed it goes from tank to the filter? im kind of confused here guys...
thanks for all of your help.
PrecisionH23a
Jul 29, 2012 10:31 AM
H22_TURBO
Oct 22, 2009 07:49 AM
Nick M
Jan 30, 2006 12:02 PM
PrecisionH23a
Jul 30, 2002 07:37 AM
PrecisionH23a
Jul 17, 2002 07:20 PM
