Will 13" stock wheel fit over GSR brakes?
Old Aug 5, 2008 | 02:23 PM
specoperformance's Avatar
Default Will 13" stock wheel fit over GSR brakes?
I just got a 96 hatch and it still has the standard 13's on it but I had the integra brakes fro the front and rear...anyone know if these tiny wheels will fit over the teg brakes?
Old Aug 5, 2008 | 02:25 PM
EL Vap133's Avatar
Default Re: Will 13" stock wheel fit over GSR brakes? (specoperformance)
No way, you need at least a 14" rim (ie the Integra RS, etc). Even some 14's don't work so just double check to make sure.
Old Aug 5, 2008 | 02:33 PM
HeikDiesel's Avatar
Default Re: Will 13" stock wheel fit over GSR brakes? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">No way, you need at least a 14" rim (ie the Integra RS, etc). Even some 14's don't work so just double check to make sure. </TD></TR></TABLE>
I know for a fact that a 13" wheel will fit over GSR brakes with the proper offset
Old Aug 6, 2008 | 10:34 AM
EL Vap133's Avatar
Default Re: Will 13" stock wheel fit over GSR brakes? (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">
I know for a fact that a 13" wheel will fit over GSR brakes with the proper offset</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specoperformance &raquo;</TD></TR><TR><TD CLASS="quote">I just got a 96 hatch and it still has the standard 13's on it but I had the integra brakes fro the front and rear...anyone know if these tiny wheels will fit over the teg brakes?</TD></TR></TABLE>
Please don't confuse the guy....
Old Aug 6, 2008 | 10:37 AM
HeikDiesel's Avatar
That's why I said proper backspacing. My bad. To the OP: No OEM honda 13" wheel will work on your car with integra brakes
Old Aug 6, 2008 | 11:29 AM
hushypushy's Avatar
The rears are not a problem, but the GSR front calipers have a little ridge on them that prevents most 14" wheels from fitting. I originally planned to run 14" Miata daisies on my del Sol, but they wouldn't clear the caliper by a long shot. My 14" Panasports do clear the brakes, just.
Unfortunately the pics are gone from this thread which shows how to get 14" rims to fit over the calipers by grinding the ridge down.
Old Aug 6, 2008 | 11:49 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">That's why I said proper backspacing. My bad. To the OP: No OEM honda 13" wheel will work on your car with integra brakes</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hushypushy &raquo;</TD></TR><TR><TD CLASS="quote">
Unfortunately the pics are gone from this thread which shows how to get 14" rims to fit over the calipers by grinding the ridge down.</TD></TR></TABLE>
True, but why get 14's up front and 13's in the rear? lol
Old Aug 6, 2008 | 01:32 PM
hushypushy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">True, but why get 14's up front and 13's in the rear? lol </TD></TR></TABLE>
Well, only the front brakes have that ridge, and that's what I was pointing out. I suggest 14's all around...that's what I'm running on my EJ1. GSR brakes in front, EX discs in the back (which are the same rear discs as the GSR, AFAIK)
boostd ls
Aug 10, 2008 07:27 AM
TurboB16A300Hpteg
Dec 29, 2007 09:59 PM
1sicsol
Apr 10, 2007 09:34 AM
2-7offsuit
26
Aug 30, 2005 08:43 AM
silentkill03
23
Nov 10, 2004 07:05 AM
