Oil in the spark plug holes HELP!!!
Old Aug 5, 2008 | 09:48 AM
Nate10-1992's Avatar
Default Oil in the spark plug holes HELP!!!
yes i did a oil change and then ran my car and it was fine then after about 20 minutes it started sputtering and shut off, it start back up but when i gave it gas it barely moved. Then when it cooled down i took out the spark plug wires and the 2 middle spark plug holes were filled with oil the #2 hole had so much that u couldnt see the spark plug. What does this mean and what will i need to do to fix this?? thnx in advanced for any help.
Old Aug 5, 2008 | 09:50 AM
PalmyBlueB20's Avatar
Default Re: Oil in the spark plug holes HELP!!! (Nate10-1992)
probably a busted seal, just get it checked at a garage they'll know what to do lol.
Old Aug 5, 2008 | 11:35 AM
vtecb18c's Avatar
Default Re: Oil in the spark plug holes HELP!!! (PalmyBlueB20)
there are o ring seals under the valve cover for the plugs...pull the valve cover off and make sure that they are all there and check for cracks or uneven seating...sounds like they just need to be replaced
Old Aug 5, 2008 | 12:09 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PalmyBlueB20 &raquo;</TD></TR><TR><TD CLASS="quote">probably a busted seal, just get it checked at a garage they'll know what to do lol.</TD></TR></TABLE>
Good thing you knew what you were talking about when you clicked that reply button
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">there are o ring seals under the valve cover for the plugs...pull the valve cover off and make sure that they are all there and check for cracks or uneven seating...sounds like they just need to be replaced</TD></TR></TABLE>
Like he said.
Just goto any local autoparts store and get a valvecover gasket set,
It should include the large gasket for the VC, and 4 small ones for the sparkplug areas.
And the VC is very simple to take off, all you need is a 10mm socket.
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
premo_si
Jan 23, 2008 08:57 PM
Jbur074
12
Dec 10, 2007 11:00 PM
alghafat424
Feb 11, 2006 12:35 PM
1SpoolnH
May 21, 2003 02:28 PM
