OMG rear disk brakes
Old Aug 5, 2008 | 06:08 AM
turboblack2door's Avatar
Default OMG rear disk brakes
So i did a rear disk brake conversion on my civic and OMG huge difference night and day so to all of you out there with drum rears on you civic do it it only takes a couple of hours and definently worth the work. I ended up using the integra rear lca's because i'm going to use the sway bar. I know the camber was going to be messed up but that's why i bought the adjustable rear camber kit
Old Aug 5, 2008 | 06:26 AM
sleeper17's Avatar
Default Re: OMG rear disk brakes (turboblack2door)
hay man could you send me some info on how exsactly you did the disc swap. i wana do that sooo bad to mine but for some reason i cant find the info i need. that would be sweet thanx. colby.
Old Aug 5, 2008 | 07:04 AM
JustAnotherRex's Avatar
Default Re: OMG rear disk brakes (sleeper17)
It is more likely that changing our your fluid and everything else is what you're noticing more than the brakes.
Did you change your proportioning valve?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper17 &raquo;</TD></TR><TR><TD CLASS="quote">hay man could you send me some info on how exsactly you did the disc swap. i wana do that sooo bad to mine but for some reason i cant find the info i need. that would be sweet thanx. colby. </TD></TR></TABLE>
Uh, see the FAQ at the top of the page or use the Search function. Been done hundreds of times.
Old Aug 5, 2008 | 07:31 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: OMG rear disk brakes (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">It is more likely that changing our your fluid and everything else is what you're noticing more than the brakes. </TD></TR></TABLE>
Couldn't have agreed more. Disc swaps are ok, but more for getting rid of drums then an actual performance upgrade.
Old Aug 5, 2008 | 07:33 AM
Default Re: OMG rear disk brakes (ComeOnKip)
i did not replace the proportioning valve. I have an ex sedan and didn't need to.
Old Aug 5, 2008 | 07:37 AM
sanimalp's Avatar
$cat /dev/urandom
eww gross.. why would you want to make your car heavier by doing a rear disc conversion..
Old Aug 5, 2008 | 08:19 AM
pxsx's Avatar
Default Re: OMG rear disk brakes (sanimalp)
because they look cool.
and are just better.
Old Aug 5, 2008 | 09:09 AM
rayzian's Avatar
Default Re: OMG rear disk brakes (pxsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pxsx &raquo;</TD></TR><TR><TD CLASS="quote">because they look cool.
and are just better. </TD></TR></TABLE>
lets not forgot how much of a pain it is to replace drum shoes....
Old Aug 5, 2008 | 12:31 PM
Red_ED8's Avatar
x2
I've had 3 crx's now, 2 with drums and 1 with disc and I couldn't feel any diff between them.
Old Aug 5, 2008 | 12:34 PM
jpnolan's Avatar
ahhh **** i just finish doing mine the other day but seeing as though im without an engine I cant test them out yet. haha but they do look SICK
Old Aug 5, 2008 | 01:43 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (jpnolan)
you can test them, they just won't be boosted, so they might suck a lot..
Old Aug 5, 2008 | 03:11 PM
Natural Aspirations's Avatar
The problem with drums is the HUGE PITA they are to adjust. I have yet to get it correct, every time i do the shoes my pedal turns to mush, if i crack the line or not.....
Old Aug 5, 2008 | 05:11 PM
Default Re: (Natural Aspirations)
simple solution. Do the conversion!
Old Aug 5, 2008 | 05:19 PM
fireant's Avatar
Default Re: (turboblack2door)
Disc/Drum stopping distances were the same. New pads and fluid on either = WIN!
Old Aug 5, 2008 | 11:43 PM
Vinceg99's Avatar
Default Re: (fireant)
If drums are adjusted properly you will actually have LESS drag from them than with rear disc's plus some people actually prefer drums when autoxing and such cause you will get less brake fade with drums. Plus drums are lighter.
Now with that all said I also did a rear disc conversion like 8 years ago for ease of changing
Old Aug 6, 2008 | 12:04 AM
EFstyle's Avatar
Default Re: (Vinceg99)
I have EK rear trailing arms i switched onto my 91 Si because of better bushing condition and I think they are about 15-20 mm bigger and id never do rear disks from here... i have DA front knuckles and i couldnt be happier with the setup...
Old Aug 6, 2008 | 12:19 AM
Zaakro's Avatar
Default Re: (EFstyle)
I like my rear disk brakes. I hate changing drum brakes. And i got mine for a really good deal
Old Aug 6, 2008 | 12:43 AM
EFstyle's Avatar
Default Re: (Zaakro)
Drums last forever anyways... yeah changing em sucks but how often is that? less brake dust, they are lighter with virtually no difference in braking... if you want better brakes... upgrade the hell out of the front IMO... either way cheers to H-T !
mechanix619
Suspension & Brakes
Nov 7, 2008 07:05 AM
eg8ynot
Nov 6, 2008 04:43 PM
eg:R
Jan 29, 2006 06:50 PM
SkRiBLaH
30
Jan 9, 2005 04:55 PM
enrique
42
Oct 25, 2003 07:56 PM
