Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Coilovers on stock struts..
Old Aug 5, 2008 | 03:12 AM
kpjo4's Avatar
Default Coilovers on stock struts..
I've read that when someone wants to lower their car they usually get new struts and if they keep the stock struts they will wear out faster.. Does the height of the drop matter on the lfie of the struts or the performance of the ride??
If I use stock struts with aftermarket coilovers and I'm just going to lower about a 1.5-2 inches, will the stock struts be fine??
Thanks alot :]
Old Aug 5, 2008 | 04:10 AM
MSchu's Avatar
My Name is Nobody
Default Re: Coilovers on stock struts.. (kpjo4)
your shocks will be fine for a shorter period... and it really depends on the spring rates you use. I would not suggest doing this for a long term solution to your ride. Shocks have a range they are designed to work in, stroke. and if you get outside that range your not going to be doing the units any good. At the same time, the shocks are designed to work with a specific range of spring rate... again if you get outside that range you are not going to get the performance you want out of that shock...eg the shock will not be able to control the spring
Old Aug 6, 2008 | 10:12 PM
khooper's Avatar
Been running maxspeed springs with stock shocks on my 2003 for a year now with no problems. I just don't know why almost everyone seems to think that stock struts/shocks will blow very shortly after installing springs.
______________________
Check out Stuart Auto Blog
Drive Safely and Move Freely
Old Aug 7, 2008 | 04:30 AM
MSchu's Avatar
My Name is Nobody
Default Re: Coilovers on stock struts.. (khooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khooper &raquo;</TD></TR><TR><TD CLASS="quote">Been running maxspeed springs with stock shocks on my 2003 for a year now with no problems. I just don't know why almost everyone seems to think that stock struts/shocks will blow very shortly after installing springs.
You miss the point... its NOT the aftermarket springs... it the aftermarket spring rates
type-ONE
Suspension & Brakes
31
Aug 28, 2009 11:01 AM
Shingo
Suspension & Brakes
Aug 25, 2005 02:08 AM
RJx
Aug 19, 2003 10:21 PM
EKB18BPR3
11
Aug 18, 2002 05:05 PM
Duck Sauce
Dec 21, 2001 07:58 AM
