Do i have to take off my stock springs to put on Coilover sleeves(ebay)??
Yes you have to use spring compressors and take the stock springs off. The coilover sleeves go in the place of the stock springs.
What actually do the spring compressors do for the coilovers.
Stretch out the springs??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Omega Blaze »</TD></TR><TR><TD CLASS="quote">What actually do the spring compressors do for the coilovers.
Stretch out the springs??</TD></TR></TABLE>
OMFG OMFG OMFG...
Im from Albany too... What car do you drive???
OMFG OMFG OMFG...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunmetal_B20_Hatch »</TD></TR><TR><TD CLASS="quote">
OMFG OMFG OMFG...
Im from Albany too... What car do you drive???</TD></TR></TABLE>
PLEASE MEET HIM, PLEASE HELP HIM..!!!! SOMEBODY PLEASE, ANYBODY..!!!!!!!
OMFG OMFG OMFG...
1. take shock/spring off
2. compress spring (as in make it shorter , compressed)
3. remove shock
4. install coil sleeve on shock
5. install new coil sleeve/shock
3. remove shock
Make sure you take the compressor off evenly. You can rent them from autozone. They come with like 2 c clip compressors. It is kinda dangerous we used to shoot the springs in suto shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC »</TD></TR><TR><TD CLASS="quote">
PLEASE MEET HIM, PLEASE HELP HIM..!!!! SOMEBODY PLEASE, ANYBODY..!!!!!!!</TD></TR></TABLE>Too bad 90% of the garbage around here is just rice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
x2
</TD></TR></TABLE>x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Cool!
95 Civic Dx
d15b7 usdm
Do you stay on the north?
Cool!
95 Civic Dx
d15b7 usdm
Lol @ streching out the springs..
Anyways, all you gotta do is:
- Buy spring compressors
- Compress springs
- Unscrew the bolts on the top
- Remove springs
- Replace with ebay sleeves
- Screw back on the top
- Profit.
- Compress springs
- Remove springs
- Profit.
Cool Cool Island Breezes. BOY-EE
lol @ fools that use spring compressors for stock civic springs.
You dont need that. Even if you did use it, you dont really use it to compress the springs. You just put a tiny bit of tension on it to take the energy out of the sping when you open up the top nut. You dont need to crush the spring at all...you're just wasting time.
You can even just take off the front shock fork, move your feet, open up the top nut without taking the shock out of the car and let the shock fly at the floor. Or use a jack underneath it if you want everything to come out slowly.
Same process for the back. Take off the LCA to shock bolt, pull the shock out of the way of the LCA a bit, put a jack underneath it, and take off the top nut. Release the jack slowly.
MUCH faster than a spring compressor.
The spring doesn't have that much energy in it anyway. You can take the whole thing off on your garage floor without a spring compressor. I've done it about 1 million times. Point away from your face and genitals. Keep your hand on the top of the wrench, aim the top mount at the garage wall's base so everything doesn't fly where you can't find it. That's my process.
OP: Once you lower the car, make sure you or whoever else is working on it clocks the bushings. If someone is helping you and they dont know what it is, LOL at them for not knowing what it is.
Your car will most likely give you a LOT of issues trying to install these. I can pretty much guarantee you that your rear suspension will not come apart without cutting, drilling, and other forms of barbarism. I have a write up on it. Do a search involving my screen name and the subject "stuck bolts".
After you take all the trouble to take it apart, you'll probably realize that the car rides like junk. If you're using stock shocks, it will ride like more junk. But the money you saved on not buying name brand parts can be spent on chiropractor appointments.
Don't waste your time, dude. Buy something nice before you take all the trouble of lowering the car.
Modified by B serious at 10:56 AM 8/5/2008
jdm jedi
Oct 11, 2008 06:36 PM
1ntensiveVTECivic
21
Aug 6, 2003 12:48 PM
