Do I Need a Tune?
do you have anything done to your car that would warrant the intake manifold? ie cams or anything....? If not your car will actually make less power if you put it on.
edit* but to answer your question no you wouldnt need a tune just for an intake manifold and a header
From: Somewhere in the United States, united states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMguy88 »</TD></TR><TR><TD CLASS="quote">do you have anything done to your car that would warrant the intake manifold? ie cams or anything....? If not your car will actually make less power if you put it on. </TD></TR></TABLE>
is this true?
is this true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg10 »</TD></TR><TR><TD CLASS="quote">
is this true?</TD></TR></TABLE>
You can say it reroutes the power, you will lose some midrange and gain some top end on a stock engine, keep in mind the losses/gains will be very minimal.
As far as tuning car, do you have anything else you want to do to it? I would finish putting the rest of the parts on and tune it all at once.
