ls vtec wierd noise?????
Old Aug 4, 2008 | 12:18 PM
lsvtecpower's Avatar
Default ls vtec wierd noise?????
ok im new to h-t so lets start of right by introducing myself. i have a da with a fully built ls vtec. skunk2 pro series springs,retainers, skunks 2 tuner 1's,ugr add. cam gears. bottom end is bored to 1.9,block girdle,arp main studs,arp rod bolts, arp head studs, cometic head gasket. AEBS type r intake mani. blox volocity stack. jdm itr 4-1 header, all brand new gsr/itr oil pump,water pump, timing belt, tenioner. ctr crank pulley, exedy stage 2 clutch,light wieght flywheel. pretty much all the goods.. ok well now to the problem firtst off y motor has about 600 miles on it. it runs great. up until about 2 weeks ago my crank pulley fell off?? while i was driving. someone didint tighten the bolt. ok so big deal got new pulley and bolt and everything put it all back together and now when i start the car it makes this noise from the timing belt side like something is just spinning freely?? as soon as i start it and when i rev it up and its coming back down in the rpms?? can anyone please help me out with this i am stumped i have been around honda's a very long time. am a tech and still never heard something like this.
Old Aug 4, 2008 | 12:47 PM
King V's Avatar
Default Re: ls vtec wierd noise????? (lsvtecpower)
First, I'd punch in the mouth whoever left your crank pulley loose. Can you describe "spinning freely" a bit more? Like a whine, groan, grating sound, etc?
Old Aug 4, 2008 | 01:08 PM
Default Re: ls vtec wierd noise????? (King V)
yeah i hear you there..lol but anyways it sounds like when i rev it up and let off the gas and it comes back down in the rps it sounds like something is spinning in the timing cover. almost like the belt is hitting the cover but its not its a metal to metal sound and when the whole thing happend i tour the whole side down to look everything back over. and noticed that the washer that goes on before the crank pulley and the covor was rubbing up agianst the crank pulley. becuse it was making this noise before the pulley acually came off. so i replaced everything. the lower timing gear and the washer and the crank pulley and stated it and its making the same noise all over agian?? im lost
Old Aug 4, 2008 | 01:54 PM
groundzerocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">First, I'd punch in the mouth whoever left your crank pulley loose. </TD></TR></TABLE>
X2....i'm stumped....i have a LS/VTEC also and i aint gotta clue....
i'm curious to what it may be.....
BTW.... there SHOULD be 2 washers.....1 against the oil pump...and the other i believe goes on AFTER the timing belt gear on the crank.....so in other words...first washer....timing gear....second washer....
please correct me if i am wrong....
Old Aug 5, 2008 | 07:13 PM
Default Re: ls vtec wierd noise????? (groundzerocivic)
well pulled the tranny tonight just for ***** and giggles.. came out to be the damm flyeheel bolt came out and was hitting up agiast the back side of the clutch.. ouch but luckily it was not that bad and now i know what it is so it will up and running people back down tommorow..lol
Old Dec 10, 2008 | 10:15 AM
b18cyacrx's Avatar
Banned
Damn man, didn't your mechanic ever hear of a torque wrench. Sorry but that **** is funny.
raidacaipo
Honda CR-V & Element
Aug 18, 2010 02:28 PM
gsr dood
Mar 23, 2006 10:21 PM
fatalman
Apr 8, 2005 12:19 PM
EFin' Kyle
Nov 10, 2004 10:00 AM
