FS 1997 GSR/JDM Front/Race Built/Daily Ohio
CAR: 1997 Acura Integra GSR 107,XXX Miles on Clean Title Chassis
Current Mileage on Rebuild Motor and Transmission is 750 Miles
Current Dyno Tune on Pump Gas is at 11PSI Making 420WHP 268WTQ
Last Set-up 575WHP 395WTQ on C16 Race Gas
MOTOR: 1995 Acura Integra GSR Long Block (with Receipt)
TRANSMISSION: 2000 Acura Integra Type-R Transmission (with Receipt)
Engine Management
Hondata S300
USDM OBD1 P28 ECU
PLX M-300 Wideband O2 Sensor Controller with Bosch O2 Sensor
PLX Wide to Narrow Band Converter
Engine Bay
LongBlock (95 GSR 85,333 miles swap before rebuild)
B18C1 Crower Rods
9.0:1 84mm CP Pistons
OEM Honda Bearings
OEM Timing Belt
OEM Water Pump
OEM Timing Belt Tensioner
OEM Timing Belt Tensioner Bolt and Spring
OEM Type R Oil Pump
OEM Bottomend Gasket Kit
Cometic 84mm Head Gasket
Supertech .5mm oversized Flat Top Nitrated Coated Intake Valves
Supertech .5mm oversized Dished Inconel Intake Valves
Supertech Titanium Retainers
Supertech Dual Coil Springs
Supertech 7deg Locks
OEM Honda Prelude Spring Type LMA
OEM Shims for LMA
OEM Valve Seals
OEM Valve Cover Gasket Kit
ARP Head Stud Kit
Hondata Intake Gasket
Golden Eagle Intake Manifold
AEM Under Drive Pulleys
Precision 1000cc Injectors
Comp Stage 3 Turbo Camshafts
Dan Benson Signature Series Sleeved Block
ERL 5Main Girdle
ARP Main Studs
Micro-polish, Chamfer, and Balance Crank
Alaniz Head Technologies Cylinder Head (Blue Printed Competition Port/Polish and Pro Chamber Work)
Motor Blueprinted and Balanced
LoveFab SS Equal Length Ram Horn Manifold
Garrett T3/T67 High-Output Stage 5 Wheel Upgrade .82 A/R
TiAL 44mm Wastegate Black - 11lb spring
Greddy Type S Blow Off Valve
Custom Piping 2.5” Black Powder Coat (Piping Beaded)
4ply Silicone Couplers
T-bolt Clamps
Custom Slow Motion Oil Feed and Return Lines
MSD 3 Bar Map Sensor
OEM Honda Resistor Box
K&N Cone Filter
ACT Clutch Kit # AI4-XXR6
ACT Streetlite Fly Wheel 12Lbs.
ARP Pressure Plate Bolts
ARP Flywheel Bolts
Quaife LSD
OEM Acura Type-R Sealed Diff Bearings
OEM Acura Type-R Diff Bolts
AEM Cam Gear
Edlebrok Cam Gear
SlowMotion Fuel Rail
SlowMotion Spark Plug Cover
SlowMotion Triple O-ring Cam Cap
OEM JDM Type-R Valve Cover and Timing Belt Cover (custom laser cut “moons” for cam gears)
AEM Fuel Filter
C&R ½ size Turbo Core Aluminum Radiator
SPAL 1750cfm Fan
Precision 750hp Intercooler
GM Style Injector Clips
Custom Greddy Oil Catch Can
3 K&N Breather Filters
SS Breather Line
Vibrant Aluminum Oil Cap with -8an Breather Port
Custom DumpTube
MSD Performance Cap
MSD Digital SCI + Ignition
MSD SS Blaster Coil
MSD 8.5mm Wires
Polyurethane Motor Mount Inserts
Custom Vacuum Manifold
Golden Eagle Triple O-ring Dip Stick
Golden Eagle VTEC Cover
Golden Eagle Scatter Shield
Exterior
New OEM JDM Frontend Conversion
VIS Carbon Fiber Hood
VIS Spoon Style Carbon Fiber Lip
Wings West Avenger Side Skirts and Rear Bumper
JSP Type R Spoiler with LED
1998 OEM Rear Tail Lights
OEM GS-R Badge
OEM VTEC Decals
3” High Flow CarSounds Catalytic
3” SS Custom Catback
3” MagnaFlow Wide-open Muffler with Tip
Custom 3” 4 Bolt Downpipe with Flex Section
Interior
Walbro 255 Fuel Pump
USDM Acura Type-R Front and Read Seats
Pioneer DEH-P840MP
Pioneer 2-way Door Sets X4
Pioneer IMPP 8” Subs
Profile 400 Watt 2 Channel Amp
AutoMeter Carbon Fiber Gauge Water Temp
AutoMeter Carbon Fiber Gauge Air Fuel Ratio
AutoMeter Carbon Fiber Gauge Volt
AutoMeter Carbon Fiber Gauge Boost
AutoMeter Carbon Fiber Gauge Oil Pressure
GaugeWorks Full A-Pillar 3 Gauge Pod
GaugeWorks Dash Cluster Bezel
Greddy Turbo Timer
Skunk2 Short Throw Shifter
Skunk2 Titanium Shift ****
MSD Shift Light
MSD Pill Set
Suspension, Brakes, and Wheels
Spoon Front Strut Bar
Spoon Rear Strut Bar
Full-Race Pro-Street Traction Bars
OmniPower Coilover- Race Set 12K Front 10K Rear
OmniPower Front and Rear Camber Kit
Goodridge Stainless Steel Brake Lines
Power Stop Cross Drilled and Slotted Rotors
AEM Brake Pads
Enkei WM7 15X6.5 4x100 Rims
Black Splin Drive Lug Nuts
BF Goodrich Drag Radials 225/50/R15 Front
BF Goodrich KDWII 205/55/R15 Rear
Locking Valve Stems
I’m sure there are things I missed……. Plus I have some random extra parts as well.
***ALL MECHANICAL AND LABOR WORK DONE AT SLOWMOTION MOTORSPORTS (EXCLUDING MACHINE SHOP WORK) ALL BODY MODIFICATIONS DONE BY VIC’S AUTO BODY***
Pics:
<FONT COLOR="blue">I’m now a stay at home dad and have no money or need for this car any longer. My loss is your gain!!
Asking Price $15,000 neg.
For quickest response Email pbsracerx@columbus.rr.com
Please feel free to ask questions or schedule a time to come and take a look.
Joshua</FONT>
Engine Management
Hondata S300
USDM OBD1 P28 ECU
Engine Bay
B18C1 Crower Rods
OEM Honda Bearings
OEM Timing Belt
OEM Water Pump
OEM Type R Oil Pump
OEM Shims for LMA
OEM Valve Seals
ARP Head Stud Kit
ERL 5Main Girdle
ARP Main Studs
T-bolt Clamps
K&N Cone Filter
ARP Flywheel Bolts
Quaife LSD
AEM Cam Gear
Edlebrok Cam Gear
AEM Fuel Filter
SPAL 1750cfm Fan
SS Breather Line
Custom DumpTube
MSD Performance Cap
MSD SS Blaster Coil
MSD 8.5mm Wires
Exterior
OEM GS-R Badge
OEM VTEC Decals
Interior
Pioneer DEH-P840MP
Greddy Turbo Timer
MSD Shift Light
MSD Pill Set
AEM Brake Pads
Locking Valve Stems
Pics:
Joshua</FONT>
Price Dropping to $13,000. Nothing wrong with the car just needs an owner who will drive it and get some use out of it. All it does now is sit in my garage collecting dust and spider webs.
Joshua
Joshua
Car now has 802 miles on it!!
PS this is a clean title car with paperwork on motor and trans...Oh yeah NO RUST and stored winters in a heated garage.
A steal for $13000
Joshua
PSS: I WILL THROW IN THE OEM REAR BUMP AND SPOILER IF YOU WANT THEM!!
A steal for $13000
Joshua
watisjdm
Jun 24, 2012 05:51 AM
watisjdm
Jun 8, 2012 07:10 AM
r1de23
Jul 15, 2009 06:30 PM
