Stroker B16A from stock honda parts?
Old Jul 22, 2002 | 08:34 AM
whobeedoobee's Avatar
Default Stroker B16A from stock honda parts?
Anyone have specs on a Stroker B16A kit using OEM honda parts. I have heard of using an LS crank stock rods and custom pistons. Has anyone (successfully) used this or a similar setup?
Old Jul 22, 2002 | 08:38 AM
Spade's Avatar
Default Re: Stroker B16A from stock honda parts? (whobeedoobee)
Don't bother......even if you could do it it wouldn't be reliable.
Old Jul 22, 2002 | 08:57 AM
teeter7467's Avatar
Default Re: Stroker B16A from stock honda parts? (C5_ALLMOTOR)
Stroker? What does that mean?
Old Jul 25, 2002 | 07:15 AM
hatchmobile's Avatar
Default Re: Stroker B16A from stock honda parts? (teeter7467)
what if you were to use a b16 block w/ a b18c crank and all that, but w/ a deckplate to match the increased block height of the b18c. wouldn't that help the reliabilty problem of the stroker motor???
Old Jul 25, 2002 | 07:57 AM
Jackson's Avatar
B17a crank and rods with ctr pistons is a good 1.7 setup with roughly 11.4:1 compression.
Old Jul 25, 2002 | 09:08 AM
you wont need a deck plate for what you want
i'm talking about making it reliable...basically just being really sleeper and having a 1.8L w/ a b16 engine code
Old Jul 25, 2002 | 10:00 AM
wc's Avatar
wc
Why?
http://www.g-speed.com/pbh/stroker-info.html
Old Jul 25, 2002 | 10:26 AM
tonyxcom's Avatar
Default Re: Stroker B16A from stock honda parts? (hatchmobile)
YOu think having a b16 with a deck plate is "sleeper"?
For the money you have to pay to get that stuff, including the deckplate welded on.... might as well get a b18c and be a "awaker"
Old Jul 25, 2002 | 04:03 PM
DarkSubRosa's Avatar
Default Re: Stroker B16A from stock honda parts? (tonyxcom)
or just not open your hood and have a fully built motor....
Old Jul 25, 2002 | 04:10 PM
98DC2-ITR's Avatar
Default Re: Stroker B16A from stock honda parts? (DarkSubRosa)
If you have that much money to play with why not buy a B16B bottom end and use the JUN kit to stroke it to over 2.0 L. The B16B is a p72(GSR/ITR) bottom end unlike the B16A. All it is is a destroked ITR engine......It loves RPM's also.....
DGKrew
Jul 1, 2013 07:39 AM
EITCP
Oct 19, 2005 12:03 PM
Mar_DC2
May 29, 2003 07:13 PM
skribblah
Apr 29, 2003 06:51 PM
H22CIVIC
Oct 2, 2001 11:45 AM
