Burning Out Fuses
Old Aug 4, 2008 | 08:11 AM
ninetysevenITR's Avatar
Default Burning Out Fuses
Hey last week I was going down a cloverleaf at a decent speed and then realized there was a bump at the bottom without anytime to slow down really. Car handled it no big deal but the car died and I later realized that my ACG(IG) fuse had burnt out so my fuel pump would not prime.
I replaced the fuse and everything was fine till I accelerated under WOT again the next day and the fuse popped again. Has anyone else had this problem before. Any certain spots I should check first for loose grounds or something?
Thanks
Old Aug 4, 2008 | 08:54 AM
citrus3000psi's Avatar
Default Re: Burning Out Fuses (ninetysevenITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninetysevenITR &raquo;</TD></TR><TR><TD CLASS="quote">Any certain spots I should check first for loose grounds or something?
It shouldn't be a loose ground, its shorting out someway/somehow. I would start my search in the rear of the car, take out the rear seats etc. Im not sure the wire path from the front to the rear of the car. I would take out the helms and look and just trace back the spots you have access to. Worst comes to worst you can always run a new line.
Old Aug 4, 2008 | 08:57 AM
walker111's Avatar
Default Re: Burning Out Fuses (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
It shouldn't be a loose ground, its shorting out someway/somehow. I would start my search in the rear of the car, take out the rear seats etc. Im not sure the wire path from the front to the rear of the car. I would take out the helms and look and just trace back the spots you have access to. Worst comes to worst you can always run a new line.</TD></TR></TABLE>
Electrical problems are the worst to deal with. Trace the wires....
Old Aug 4, 2008 | 04:19 PM
DVC2008's Avatar
Mine did the same thing $2500 bucks later I found out why.
Old Aug 5, 2008 | 06:57 AM
what did the problem end up being?
Old Aug 5, 2008 | 08:52 PM
robfrmny21's Avatar
check the wires going to the second 02 sensor
ive seen when the car hits some thing pulls back the protective cover on a few wires , they only touch when the exhaust moves alot ie power shifting. so check that and get back to me
Old Aug 6, 2008 | 08:01 AM
BMaDOHC's Avatar
Default Re: (robfrmny21)
check all aftermarket goodies. problems like this occur usually from either something hacked up in the past or aftermarket stuff routed incorrectly. alarms, stereo equipment,etc...neon lightz
Old Aug 6, 2008 | 03:08 PM
you my friend are a genius. the wires on the secondary 02 are worn thru and are very tight against a bar... makes sense when i hit bumps it shorts. Ill replace the parts and keep u updated! thank you
integra123456
Jan 13, 2008 09:47 PM
ek4shizzle
Sep 24, 2007 02:10 PM
BLUE EH3
Mar 15, 2007 12:24 PM
bustah49
Nov 1, 2004 08:38 PM
4dohs4mohoes
Apr 2, 2004 05:46 AM
