VSS PROBLEM (searched)
ok i have changed the damn fuse at least 3 times and it still keeps blowing. I talked to a guy at honda and he saiys there is a wire that runs under the IM that wears away and grouns out. I changed teh fuse again tonight and now it didnt work at all. I know the alt. is wired into that fuse also. Will the alt. still charge is this wire is fucked?
Re: VSS PROBLEM (boo bees)
well did you check out the wire under the manifold? shorts suck ballz, Always hard to find.............................John
dont forget to physically inpect the VSS itself....
it may be subject to broken wires and such... besides me breaking mine in half , it was covered in dirt and oil....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Will the alt. still charge is this wire is fucked?</TD></TR></TABLE>
no it will not, i had this same problem last week. blew 6 times on my way home from work. took a look at it and had a loose wire for the primary o2, so loose it was just about coming out. fixed that and havent had the problem since ::crosses fingers::
check some of those wires, hope i could be of some help.
Re: VSS PROBLEM (sean)
Yeah i remeber that i had to splice some wires on the O2 by the cat. maybe they are shorting. couls that be the cause? If so that would make a whole lot of sense.
yes it can be, thats what i believe caused mine. just double check your wiring, make sure nothing is bare or loose or actually falling out. finding a short is a pain in the ***.
