Pro1 cams & JRSC
I am very new to the F/I but i keep reading that the Pro1s work well with turbo setups, Well then would they work good on a JRSC as well?
Modified by MyLilCivic at 9:16 AM 8/4/2008
Just from what I've read on here the Pro1s are going to be to big for your application. I'm assuming with your supercharger setup you will be making 300whp which is probably going to be better suited for the Tuner1 cams. The pro1s aren't recommended unless you are using a GT35 (650hp) or larger turbo by Jeff Evans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led »</TD></TR><TR><TD CLASS="quote">Just from what I've read on here the Pro1s are going to be to big for your application. I'm assuming with your supercharger setup you will be making 300whp which is probably going to be better suited for the Tuner1 cams. The pro1s aren't recommended unless you are using a GT35 (650hp) or larger turbo by Jeff Evans.</TD></TR></TABLE>
Agreed, tuner 1's or stock are your best bet. Honestly, I doubt you would see any huge gains over stock cams. Tuner 2's and Pro 1's are for Gt35r and bigger turbos making 500+ whp. Good luck though
IntegraR0064
Jul 20, 2002 09:55 AM
IntegraR0064
Jun 27, 2002 08:45 PM
