problem after rear brake swap
Old Aug 4, 2008 | 05:20 AM
opera936's Avatar
Default problem after rear brake swap
I did a rear disk conversion on my 00 dx hatchback a few weeks ago. I felt the car stopped differently at the first place, but didn't pay much attention to it, because i thought it was supposed to stop different than the drum setup. However, when i drove my cousin's 97 civic dx, with drums, it stopped MUCH better than my hb. The conversion consisted of swapping out the trailing arms with an si's, and replacing the MC with an si's. I have never changed the booster, nor the prop since research shows that the prop valve is the same as the si's. Does my problem lie on the booster? any help would be greatly appreciated
Old Aug 4, 2008 | 05:44 AM
JDM_SOHC's Avatar
Default Re: problem after rear brake swap (opera936)
did you bleed the brakes properly..?? i had a problem like this too and it was cuz my brakes weren't bled 100% and in the right order on top of that....
Old Aug 4, 2008 | 05:50 AM
opera936's Avatar
so my problem lies on the bleeding part? no booster swap required? thanks again
Old Aug 4, 2008 | 05:55 AM
JDM_SOHC's Avatar
Default Re: (opera936)
Yeah man I did the same brake swap as you and my brakes were SOOOOO sluggish... So I bought a 15/16's civic MC and than re-bled the brakes from furthest away from the MC to closest "rear right, rear left, front right, front left" I believe was how I bled them and after that my car braked awesome..!! Also, introducing your brake lines to more/less pressure also creates air pockets on some occasions, which will in turn need to bled out so i'd say give the bleeding a shot since it's free and most likely your answer... If that doesn't work come back and i'll give you another step to try... GL man
Old Aug 4, 2008 | 06:46 PM
opera936's Avatar
thank you. i'll post back and let you know the results
Old Aug 4, 2008 | 09:17 PM
JDM_SOHC's Avatar
k
Old Aug 5, 2008 | 08:03 AM
robfrmny21's Avatar
all the air must be removed in order to diag this correctly
Old Aug 5, 2008 | 08:32 AM
B18CivicEJ8's Avatar
Default Re: (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote"> and than re-bled the brakes from furthest away from the MC to closest "rear right, rear left, front right, front left" </TD></TR></TABLE>
That is the incorrect bleed pattern. According to the Helms service manual, you are supposed to bleed rear right, front left, rear left, front right.
Old Aug 6, 2008 | 05:58 PM
opera936's Avatar
lol thanks for all the replies, i followed the bleeding pattern from honda's manual exact same order like B18CivicEJ8 mentioned. My brake now brakes awesome!!@
hatchet_honda
Oct 10, 2010 10:04 PM
allmotorEG6civic
29
Apr 4, 2004 12:26 PM
91civ
11
Jun 26, 2002 06:30 PM
