timing off in my 1984 civic hatchabck dx
the timing is off in my civic and i dont know how to fix it its off so much where it wont start and i cant use a timing light without it started andyone wanna give me some tips on how to fix it
Ignition timing does not just go off all by itself. I bet your timing belt has slipped. If it has, you need to change the timing belt and the water pump.
Check your cam timing first (Service Manual) then check your ignition timing. Buy a timing light (less than $30) or borrow one from AutoZone.
Scott
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 84hatchdx »</TD></TR><TR><TD CLASS="quote">well i replaced the head gasket and too the belt off and didnt mark it or anything so now it is off</TD></TR></TABLE>
Cam timing is your problem. Both the cam and the crank have a "key" that needs to be at 12 o'clock when the engine is at TDC. Get that squared away and your problem is solved.
Scott
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbstd »</TD></TR><TR><TD CLASS="quote">
Scott
Scott
luvs2spooge
May 18, 2007 05:42 PM
dr_latino999
Dec 2, 2004 09:55 PM
