alignment w/ 26" slicks
Old Aug 3, 2008 | 06:50 PM
93DelSolSiR's Avatar
Default alignment w/ 26" slicks
im just wondering how most you guys out there are using for a procedure for lining up your cars. alignment machine, toe plates, ect...????
Old Aug 3, 2008 | 07:14 PM
TheWickedOne's Avatar
2 pairs of jack stands, string, and tape measure
May not be as precise, but has worked for me in the past
Old Aug 4, 2008 | 04:40 AM
DaveF's Avatar
Default Re: (TheWickedOne)
i had my hotrod car on 2 differant alignment racks this year already. the 1st time, i did it with no front end on the car, and the 2nd time i had the front on it.
the 1st time, the front tires looked to have major tow out, and after putting the front end on the car, i realized the car needed to be raised up another 1.5 inches or so, thus throwing the alignment off
the 2nd time we aligned the car, at ride hight, with the front on the car... after taking it to the track, the car pulled hard to the right. bring it back into the pit, get out the tape measure (measure front and back side of front tires at the same hight) the car had major tow in... and also found out the alignment place did not know how to tighten jam nuts on radius rods we adjusted the tow, to about 1/8inch out, the car went very straight on the next pass...
Old Aug 4, 2008 | 06:07 AM
thanks for your input guys, i have alignd cars with the machine before with just the stock rims on the front instead of slicks and have no issues. but with 26's im wondering if its going to cause an issue on the machine?
Old Aug 4, 2008 | 06:22 AM
JDCIVIC's Avatar
always allign it how you gonna run it on the track
Old Aug 4, 2008 | 06:35 AM
ShawnR's Avatar
Default Re: (93DelSolSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DelSolSiR &raquo;</TD></TR><TR><TD CLASS="quote">thanks for your input guys, i have alignd cars with the machine before with just the stock rims on the front instead of slicks and have no issues. but with 26's im wondering if its going to cause an issue on the machine?</TD></TR></TABLE>
i had my car aligned on some stock steels and it go goes straight...
Old Aug 4, 2008 | 06:55 AM
I've used steel rims and race wheels, 13's or 15's.. if its straight on one wheel, it should be straight with others.. unless the rim is wicked bent.
Old Aug 4, 2008 | 07:24 AM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWickedOne &raquo;</TD></TR><TR><TD CLASS="quote">
unless the rim is wicked bent. </TD></TR></TABLE>
lmaooo, you said wicked. Can you say that with a boston accent
Old Aug 4, 2008 | 07:25 AM
thats kinda what i was thinking if i align it with stock rims as long as the toe is set right then once the slicks are on its shouldent make a diffrence the steering will still be straight correct me if im wrong i just dont want to casue any problems at 150+mph
Old Aug 4, 2008 | 07:29 AM
Innes's Avatar
correct, most alignment places i have dealt with want street wheels/tires on the car when aligning to make it easier to work with and once the alignment is set even with street wheels/tires the settings will be exactly the same for any rim/tire combo you put onto the vehicle (even different tire sizes)
we have some 235/60/15 BFG Drag Radials that we put on the car when towing it and sitting around the shop that we do the alignments with, take them off, put the 24.5s or 26s on the car and all settings are the same
Old Aug 4, 2008 | 07:38 AM
awsome thank you for the info guys!
Old Aug 4, 2008 | 08:39 AM
Default Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">
lmaooo, you said wicked. Can you say that with a boston accent </TD></TR></TABLE>
"WAACKAD"
Old Aug 4, 2008 | 09:45 AM
88ED8's Avatar
Default Re: (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">also found out the alignment place did not know how to tighten jam nuts on radius rods </TD></TR></TABLE>
I know how you feel...
tony1
Nov 18, 2009 06:23 AM
J.nguyen
Nov 7, 2005 05:41 PM
mickey513
Dec 17, 2004 02:18 PM
garados
Oct 30, 2004 10:35 PM
nEoMuGen
Nov 9, 2001 08:07 PM
