vss shot? would it cause limp mode?
My speedo does not work, I think the VSS is shot after the clutch job. I tested to see if power was getting to the sensor at the harness, via a test light and all was good. The car has no speedo, and I cannot get it to rev past 3700 on my tach. It is throwing cel number 9 for the cylinder position sensor This is odd because I usually have the egr valve CEL . It also blows the ecu under the hood fuse intermitantly.
How many wires are connected from the sensor to the harness? Maybe one broke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">So what kind of car is this?</TD></TR></TABLE>
yes, it will put your ecu in limp mode. any cel will do that.
1fstlude
Dec 10, 2011 06:24 AM
