aem ems in k-swapped teg?
Old Aug 3, 2008 | 04:10 PM
fast_fourdoor's Avatar
Default aem ems in k-swapped teg?
hey, I just finished my 2006 k20 swap into a 95 integra. I am using the hasport conversion harness and an aem ems 30-1030. The car starts and runs, but not well. when my laptop is on the throttle reads 100% when the throttle body is closed and decreases as you apply gas...also the engine load in Kpa reads over 100 even when the car is off...are these things normal, and if not how would i make them read properly?
Thanks guys
Old Aug 3, 2008 | 04:22 PM
hpimichael02's Avatar
got any pics of the build?
Old Aug 3, 2008 | 04:33 PM
Default Re: (hpimichael02)
ok here are some pics.
I really need some input as to what the problem may be, there is noone in my area that is familiar with my setup so this is my only option.
Old Aug 3, 2008 | 06:54 PM
Circusraven's Avatar
Default Re: (fast_fourdoor)
Sorry I can't help you with your problem man, as I'm not familiar with this kinds of swap. Just want to give you compliments on the car, it looks GREAT! very jealous.
Old Aug 3, 2008 | 08:55 PM
Default Re: (Circusraven)
^thanks man! I'm going over all my ecu plug pinouts tomorrow to make sure that i got them right...seems like the tps is just pinned backwards.
Old Aug 4, 2008 | 08:11 AM
could it be that i'm using a type s throttle body and a base model harness (i.e. the tps is on the opposite side of the throttle body) This would make it read the voltage reversed correct?
Old Aug 4, 2008 | 08:28 AM
JDMguy88's Avatar
ya it sounds like the tps is just reversed somehow
Old Aug 6, 2008 | 02:11 PM
Switched the polarity on my tps and it runs a lot better now...problem solved, thanks guys
sshh
Engine Management and Tuning
Feb 11, 2011 09:49 AM
Lonnie
Mar 22, 2007 12:11 PM
alpha
Apr 28, 2006 10:10 PM
done
Feb 13, 2004 09:42 PM
Formula 1
Aug 28, 2003 07:04 PM
