EX cluster in CX no speedo (EK)
Old Aug 3, 2008 | 03:51 PM
nicenlow1's Avatar
Default EX cluster in CX no speedo (EK)
so i have a ex cluster in my cx and the speedo doesnt work i noticed a extra plug in on the ex harness compared to the cx. i read it was plug and play so whats the problem?
Old Aug 3, 2008 | 04:39 PM
BlueIntegraBoy's Avatar
Default Re: EX cluster in CX no speedo (nicenlow1)
It is plug and play. The extra plug is for the cruise control plug which you will not need to plug in. Did you put in the CX speedo from your original cluster into the EX cluster? If so, the screws might not be tight enough. Or did you just put in everything from the EX cluster into your CX? If so, you might have a bad speedo.
Old Aug 4, 2008 | 12:03 PM
nicenlow1's Avatar
naa ive tried 2 differ speedos and VSS and still so speedo. maybe bad connection on VSS?
Old Aug 4, 2008 | 11:21 PM
Default Re: (nicenlow1)
Corrosion on the VSS plug can do that. Perhaps cleaning the metal contacts will make it will better.
Mennouth
Aug 1, 2006 08:26 AM
JDM_Frijoles
May 24, 2006 01:57 PM
ekdriven
Mar 11, 2005 06:06 AM
Hatch It
Nov 9, 2004 05:29 PM
andykatz1
Jul 17, 2002 10:44 PM
