tranny shaking and throwout bearing is done for.
Old Aug 3, 2008 | 12:40 PM
dc2long's Avatar
Default tranny shaking and throwout bearing is done for.
what could happen to a tranny if the throwout bearing is messed up and it vibrates?
For the last 6 months, my tranny has been vibrating quite a bit and it makes a loud whirring sound when i release the clutch. Besides all that, my tranny still shifts smoothly and feels like everything works fine because i redline once awhile and nothing bad happens.
My mechanic says my tranny is vibrating quite a bit and i mite need to rebuild it soon.
has anyone had a similar problem and what did you do to fix it?
my clutch is only 1 year old and its oem if that helps.
Old Aug 3, 2008 | 03:48 PM
HONDRETTI's Avatar
Default Re: tranny shaking and throwout bearing is done for. (dc2long)
hows your clutch? just replace your clutch and replace the tob. i think youre supposed to replace it as maintenance, anyway
Old Aug 3, 2008 | 04:26 PM
SleeperGSR's Avatar
Default Re: tranny shaking and throwout bearing is done for. (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">hows your clutch? just replace your clutch and replace the tob. i think youre supposed to replace it as maintenance, anyway</TD></TR></TABLE>
Do you know about how often??? I'm having some tranny problems too. I do alot of HPDE and auto-x, i was wondering if i was beating on the car or it just wore out. I really don't think i'm beating on it tho. It's a 96 gsr 108K, origional everything related to the engine and tranny.
On a side note, i do have poly bushings for the suspension, could that make for an excess load on motor mounts/shift linkage bushings??? I have a feeling it is, just looking for some opinions.
Old Aug 3, 2008 | 08:52 PM
dc2long's Avatar
my clutch is relatively new. i got it about 1 year ago and it still catches.
when i hold the clutch pedal down, i feel vibrations.
88 EF Hatch
Oct 4, 2009 05:27 PM
93sihatchy
Jun 12, 2007 10:35 AM
bambbrose
Dec 12, 2004 10:17 PM
civicmark
18
Feb 12, 2004 12:46 PM
StimpyBoy
Jun 23, 2003 01:33 PM
