ls/vtec leaking oil. HELP
hello, i have a problem with my ls/vtec leaking lots of oil threw the oil pan. i changed it 2x and still leaks.. its a b18a block, itr pistons. would i need a breather?? if so which would work best..
thanks.
thanks.
do you have a gasket on it? Are you using a b18a oilpan? Try using some Copper RTV sealant ontop of the gasket and tighten down all your bolts to the spec listed in your haynes/chilton
this might be silly but did oucheck the threads inside the oil pan. that is why mine leaks someone before i owed the car striped put the oil pan threads. you could try jb weld too.
im ion the second gasket. i put RTV on it and still leaks alot.. i didnt torque the tho. when i go in vtec then it well leak a lot. and some oil is going threw the oil filter,,, whats happing?? would a breather work??
92integraVTECgsr
20
Sep 12, 2009 03:01 PM
