HELP WITH SANDING AND PRIMER!
Old Aug 3, 2008 | 08:47 AM
DelSol12345's Avatar
Default HELP WITH SANDING AND PRIMER!
Hi, I would like to primer my car but first i have to sand it down. Does anyone know what grain sand paper i should use? thanks!
Old Aug 3, 2008 | 09:09 AM
turboteg90's's Avatar
* B A N N E D *
Default Re: HELP WITH SANDING AND PRIMER! (DelSol12345)
go to the paint and body forum.for fast answers
Old Aug 3, 2008 | 10:55 AM
greenej8's Avatar
Default Re: HELP WITH SANDING AND PRIMER! (turboteg90's)
That depends if you have to do body work or if your just wanting to scuff it for paint prep? If your good to go on body you can just use Scotch-Brite Red scuff pads available at any paint store. These will scuff the body to get it ready for primer. After that for any imperfections use 150 autobody paper and then 320 for finish sanding before paint.
Old Aug 3, 2008 | 11:12 AM
Hanmin's Avatar
scotch brite to scuff off the clear coat good, then primer.
Old Aug 3, 2008 | 01:59 PM
93beccalx's Avatar
Default Re: (Hanmin)
I also heard that it's a good idea to use a cleaning solvent to remove any of the wax/clear coat that may get trapped in the paint when you sand.
MurtazaDSM
Paint and Body
Jun 1, 2011 11:08 AM
ken9
Paint and Body
Dec 2, 2008 04:43 PM
gsr~hatch
Feb 18, 2004 05:44 PM
RacerBoy
Jan 13, 2003 08:24 PM
Unjockable
Oct 8, 2001 09:38 AM
