LCA bushing removal/install
Old Aug 3, 2008 | 08:20 AM
kornerk12's Avatar
Default LCA bushing removal/install
Im trying to replace these bushings. I had a press on them and it wasnt really moving at all. What is the easiest way to remove these ? Then how do I install them ? I read something about turning bushings ? Will there be a directional mark or anything on them ?
Old Aug 3, 2008 | 09:07 AM
slamdlude's Avatar
Default Re: LCA bushing removal/install (kornerk12)
The bushings are pressed in so they have to be pressed out. It takes quite a bit of force to get them out. Just keep pressing until they come out. It isn't an easy job to get them out. Once you get the first one out the rest will be much easier. I replaced mine with polyurethane bushings, no pressing involved on the install of those.
Old Aug 3, 2008 | 11:39 AM
kornerk12's Avatar
Default Re: LCA bushing removal/install (slamdlude)
you have to press along the metal outside section of the bearing correct using something that is the same size as the opening for the bushing. I tried pushing in the center and it ripped the bushing apart and left the metal along the outside. What did u use to press them out ?
Old Aug 3, 2008 | 06:16 PM
slamdlude's Avatar
Yes, everything has to come out in order to be able to get the new ones in. I used a socket flipped upside down to push mine out with.
Old Aug 3, 2008 | 07:16 PM
kornerk12's Avatar
what size because i used one that was just about right and it pushed it into the metal sleeve. Also is there a way to push it out, like is the hole tapered or anything or can you push it out either way ?
Old Aug 3, 2008 | 07:25 PM
jlude90's Avatar
i get in there with a hacksaw and cut the sleeve and then drive a chisel in there to spread it out, and then clamp on with some vice grips and turn them, rolling the sleeve onto the pliers and pulling out at the same time
Old Aug 3, 2008 | 07:44 PM
kornerk12's Avatar
Default Re: (jlude90)
that would work but im alittle nervous doing that because i thought you werent supposed to damage the surface where the bushing sits.
Old Aug 5, 2008 | 06:54 AM
subydoored's Avatar
Default Re: (kornerk12)
ok the way its done is to get a propane tourch heat the rubber and chisel that out then after the rubber is gone carefully remove the metal sleeve.
Old Aug 5, 2008 | 07:32 AM
kornerk12's Avatar
Default Re: (subydoored)
the problem is just getting that metal sleeve out
Old Aug 5, 2008 | 08:40 AM
subydoored's Avatar
very small chesell and some time took me like an hour each one.
Old Aug 5, 2008 | 11:24 AM
jlude90's Avatar
i've not had a problem with hitting mine with the hacksaw
Old Aug 5, 2008 | 02:37 PM
subydoored's Avatar
hack saw took to long the chisel deffently went faster with me. reminds me i got do my rears next the fronts on are done and i love them
Old Aug 8, 2008 | 06:20 PM
kornerk12's Avatar
well i got them out. Now for the install.
Where am i greasing ? Im using factory replacement bushings. Am i greasing the sleeve where it touches the LCA or do i just grease the bushing around the outside that would touch the subframe? (I guess the reason would be for longevity in that case)
Old Aug 9, 2008 | 03:52 PM
kornerk12's Avatar
well i got the lca bushings out. Im trying to get the shock bushings out and they are being a bitch.
Old Aug 9, 2008 | 09:27 PM
kornerk12's Avatar
also ive been reading that if the car is lowered u must offset the bushing. How much and how do u do this ?
Old Aug 10, 2008 | 06:11 PM
jlude90's Avatar
jack the car up by the lower control arm like when you load it to tighten suspension parts
and then you just barely loosen the bolt and then TQ it back down
kyleag989
Honda Civic (2001 - 2005)
Feb 5, 2018 03:20 PM
JohnnyEF
12
Feb 25, 2014 04:57 AM
spatula
Dec 29, 2008 02:46 PM
Chef Andre
Suspension & Brakes
26
Dec 21, 2008 11:38 PM
wadafa
Mar 19, 2003 04:24 AM
