Suspension & Brakes Theory, alignment, spring rates....
Alignment Settings for first track day?
Old Aug 3, 2008 | 08:08 AM
rrcipolla's Avatar
Default Alignment Settings for first track day?
I have my first track day coming up in September and I was wondering what camber settings I'm looking for. I have a '93 civic coupe. Thanks.
Richard
Old Aug 3, 2008 | 08:41 AM
Targa250R's Avatar
be professional
Default Re: Alignment Settings for first track day? (rrcipolla)
If it's your first track day, forget the car because it isn't going to matter. Just pay attention to your instructor and watch for flags, traffic, hand signals, lines, braking points, etc. All of that is WAY more important, and if you're too busy screwing with the car, it will go right over your head.
Just take note of your inputs and the car's behavior on track, and check your tire wear after sessions. Make some notes and ask about alignment settings after the event.
Besides, we need a lot more information to get you in the ballpark anyway.
Old Aug 3, 2008 | 10:22 AM
rrcipolla's Avatar
Default Re: Alignment Settings for first track day? (Targa250R)
Hey thanks for the response. I agree with you about not screwing with the car, and I haven't riced out anything- all stock. But my alignment now is way off- car doesn't track straight and I don't want to wear my new tires. So while there I might as well specify my settings so I don't get positive camber and I don't trust the factory settings.
Old Aug 3, 2008 | 06:01 PM
Targa250R's Avatar
be professional
In that case, have the alignment shop set the toe to exactly 0.00 degrees at both front corners, and very slight toe-in at the rear (nothing excessive; stay close to the center of the factory spec tolerance range). This will net you minimal tire wear and keep the car stable.
Camber is not independently adjustable on a double wishbone Honda without an aftermarket adjustment kit, so there's nothing much you can do with it.
Ahknodd
17
May 9, 2008 01:02 PM
rim racer
Nov 19, 2003 07:01 PM
Ponyboy
May 3, 2002 05:47 AM
Ponyboy
Honda S2000
Apr 23, 2002 03:23 PM
Greyout
Feb 18, 2002 02:35 PM
