HELP Water is leaking from my motor
Old Aug 3, 2008 | 06:30 AM
scspeed's Avatar
Default HELP Water is leaking from my motor
Water is leaking from the driverside of my motor. I just bought this motor and had it swaped in. Idk what it could be. Its like a mid to slow drip. Waterpump?? If so how do i tell????
Old Aug 3, 2008 | 07:11 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP Water is leaking from my motor (scspeed)
Pull the timing belt cover and look.
Old Aug 3, 2008 | 07:57 AM
scspeed's Avatar
Default Re: HELP Water is leaking from my motor (Dogginator)
Ok. how would ik if it is comming form the block?? WHich i hope to god it is not. It drips while the car runs. could it just be a hose too or??
Old Aug 3, 2008 | 08:01 AM
hon2984's Avatar
if u just PAID to have it swapped in take it back.
I know i damn well wont send a car out of the shop leaking anything ( unless the customer knows about it).
Part of installing an engine is making sure EVERYTHING is done and done correctly.
Old Aug 3, 2008 | 08:19 AM
scspeed's Avatar
Default Re: HELP Water is leaking from my motor (hon2984)
well it wasnt done by a shop. i had a friend help put it in. the motor was not new either. so what could this leaking water mean? its coming from waht looks like below the timing belt cover and only when it is running. also does the timing belt run the pump??
Old Aug 3, 2008 | 08:28 AM
hon2984's Avatar
yes the belt runs it. your friend must not be to smart. If u had the motor out the 100,000 mile services should have been done new timing belt, waterpump and tensioner. considering it way easier to do that stuff with the engine out of the car.
yes that does sound right for your leakage. double check all you hoses. take a look around the heater core lines and there should be some small coolant lines near the IACV and FITV if your engine is equipped.
808k20a2
May 4, 2018 10:35 AM
Shaw14
38
Aug 25, 2009 07:27 PM
vtek9
Sep 2, 2007 09:55 PM
.Unknown.
Sep 15, 2005 07:35 PM
Ej94
May 17, 2004 04:12 PM
