need help picking a turbo manifold....BUILD SPECS!
Old Aug 3, 2008 | 06:05 AM
g0tgot's Avatar
Default need help picking a turbo ....BUILD SPECS!
LS/Vtec
ACL ROd Bearings, thrust washers the whole 9 yeards
balanced crank
wiseco 8-1 pistons
CTR valvetrain
stock gsr head (getting cams at a later date, looking at GUDE cams "Bill Gude")
brand new seals, brand new hone, brand new piston rings
I am looking for a sleeper/ reliability street possibly daily driver setup....
I dont mash hard at all or very often, only when i need to..
Possibly going to tune on Hondata s300 (its a bit pricey though)
Old Aug 3, 2008 | 06:06 AM
g0tgot's Avatar
Default Re: need help picking a turbo ....BUILD SPECS! (g0tgot)
i dont know if i can run a GT35R is it too big for my set up?
Old Aug 3, 2008 | 08:16 AM
95dxsir2's Avatar
what kinda power are you looking for, and how fast do you want spool?
Old Aug 3, 2008 | 09:30 AM
g0tgot's Avatar
i would like to spool moderatly quick , and i dont know how much HP this build can handle....i dont want to overdo it....if i can maybe 350HP reliable? But on the other hadn, i love the sling shot affect......I am going to be a daily driver, so maybe GT35R is overkill?
Modified by g0tgot at 5:51 AM 8/5/2008
Old Aug 5, 2008 | 04:51 AM
g0tgot's Avatar
bump.....
Old Aug 5, 2008 | 05:43 AM
morgan@synapse motorsport's Avatar
Default Re: (g0tgot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot &raquo;</TD></TR><TR><TD CLASS="quote">i would like to spool moderatly quick , and i dont know how much HP this build can handle....i dont want to overdo it....if i can maybe 350HP reliable? But on the other hadn, i love the sling shot affect......I am going to be a daily driver, so maybe GT35R is overkill?
Modified by g0tgot at 5:51 AM 8/5/2008</TD></TR></TABLE>
35r is definately overkill. good turbo no doubt, but unecessary lag, for power potential you have no intention on using.
on a built block with a stock head, most of our customers are sticking with around 350-400whp with either 57 trims, or gt3076r's.
Old Aug 5, 2008 | 07:46 AM
TheShodan's Avatar
Moderator
Default Re: (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">
on a built block with a stock head, most of our customers are sticking with around 350-400whp with either 57 trims, or gt3076r's.</TD></TR></TABLE>
He's right. Anything that is 61lbs/min or so is just a bit too big. You can use the above or go with the Borg-Warner S256 or S258 for even more midrange power. Also, with that low of a compression you'll lose even more response with such a large turbo.
95gsr@530
Sep 23, 2015 04:07 AM
uniquewheels08
Dec 14, 2010 11:12 PM
uniquewheels08
Dec 13, 2010 02:54 PM
mtownek9
Oct 3, 2007 08:20 PM
turbob18a1
Apr 18, 2003 04:03 AM
