What kind of Radiator hoses do i need when swapping a b16 into a ef chassis?, and would a b18a1 powe
What kind of Radiator hoses do i need when swapping a b16 into a ef chassis? and would a b18a1 powersteering motor fit on a b16a? also those a crx front dash fit on a 91 civic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-R32 »</TD></TR><TR><TD CLASS="quote">What kind of Radiator hoses do i need when swapping a b16 into a ef chassis? and would a b18a1 powersteering motor fit on a b16a? also those a crx front dash fit on a 91 civic?</TD></TR></TABLE>
Radiator Hoses (check http://www.HAsport.com , I believe one is a '92 GSR, and one is a '90 GSR)
I used a 99si upper and a 90-93 integra lower, and yes a b18 power steering pump will fit on a b16 block
The Stock Civic Radiator Will Work, And For The Radiator Hoses, I Would Just Go Buy A Radiator Flex Hose At An Auto Parts Store, Its Cheap As Hell And Can Cut To Fit, And It Flexes To Any Curve. I Like It B/C I Dont Have To Make A Trip To The Junk Yard, And If Buying A GSR Upper And DA Lowers It Will Cost Way More Then Flex Hose.
negum
Sep 7, 2008 03:41 PM
red_EF9Si
Feb 28, 2006 09:21 AM
