damn check light ahhhh
Old Aug 2, 2008 | 07:10 PM
MyEfSi2Slow's Avatar
Default damn check light ahhhh
can someone show/tell me how to check why my check light keeps comming on? i replaced my o2 sensor, people tell me to rip my carpet on the passenger side so i can read the check light but do i need any tools or whatsoever to read them? can it be my catalytic converter even if theres no o2 sensor to that? please help im drivin on expired tags and im on a really tite budget,
i have a 1990 integra rs 2dr, thanks everyone
Old Aug 2, 2008 | 07:56 PM
BlueIntegraBoy's Avatar
Default Re: damn check light ahhhh (MyEfSi2Slow)
I believe there's a light under the pass seat to check for the CEL (or was that the 1st gen).
Old Aug 2, 2008 | 08:05 PM
haha yea boy, i found out how to do it, but ill do it tomora after work, if others need instruction heres a link
http://www.team-integra.net/se...D=982
Old Aug 3, 2008 | 10:44 AM
hey guys still needing help, how do i read the check blinks? is it right when i turn the key? cuz when i turn the key the light beeps one long time, then 9 times after that, so is that a 19 or a nine? help me out please thanks alot
Old Aug 3, 2008 | 10:53 AM
Horseofcourse's Avatar
check the codes while its running. count slow. Sometimes other codes will pop up only when its running.
Old Aug 3, 2008 | 10:55 AM
integra1991's Avatar
I did not need special tools, but i might have just been lucky. when you fine your ecu you have to count the blinks and the blinks translate in to what the problem. I am not sure where you would get the blink translation though. i have mine in my manuals. if your trying just to pass smog i changed my cat my muffler my spark plug my air filter and dumped sea foam in my gas tank and crank case( sea foam in a petroleum base product that helps clean all the carcon out of your engine). changed the oil and the o2 sensor along with the pvc valve and the fuel filter and oil filter.
Old Aug 3, 2008 | 11:02 AM
Default Re: damn check light ahhhh (Horseofcourse)
so i gota turn the car on then read it? and when i turn the key do i read the blinks right away?
Old Aug 3, 2008 | 11:30 AM
Start the engine!! And count right after you start the car there should be a few second delay before it stars. There will be a gap between codes if there is more than one.
Old Aug 3, 2008 | 07:02 PM
so waht does check light 19 mean?
Old Aug 3, 2008 | 07:06 PM
i mean check light 9, something about my cylinder? can someone explain
19 Automatic transmission lockup control valve
Old Aug 3, 2008 | 07:17 PM
Default Re: (Horseofcourse)
i read up on code 9, its for my cyp sensor, people say its my distributor but i have a brand new one in, could someone show me how its supposed to be wired up?
the_EG_k1d
Mar 28, 2008 07:35 AM
. L i z
Dec 23, 2005 12:39 PM
NCcwITR
Oct 27, 2003 03:07 PM
B18EG6
Sep 1, 2002 08:15 AM
