clutch not engaging
Old Aug 2, 2008 | 03:50 PM
thedudefromjerz's Avatar
Default clutch not engaging
Well when i pull my clutch arm up it feels very light and feels like the bearing is not making contact with the pressure plate. Also my motor wont turn when i rotate the crank pulley almost like the clutch is stuck on the flywheel.
Old Aug 2, 2008 | 09:57 PM
Default Re: clutch not engaging (thedudefromjerz)
what u guys think is the problem
Old Aug 2, 2008 | 09:59 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedudefromjerz &raquo;</TD></TR><TR><TD CLASS="quote"> Also my motor wont turn when i rotate the crank pulley almost like the clutch is stuck on the flywheel.</TD></TR></TABLE>
are you rotating the pulley or the bolt that holds the pulley on?
Old Aug 3, 2008 | 12:01 AM
tyler100's Avatar
Default Re: clutch not engaging (BILLETGRIP)
put a 19mm or 17mm socket on the crank pully bolt. and turn it over. mabe need a new throwout bearing.
Old Aug 3, 2008 | 06:00 PM
im rotating the bolt which is rotating the pulley. i pulled the trans and now the crank turns. so i dont know what the roblem is. its like the bearing isnt making contact with the ressure plate.
Old Aug 3, 2008 | 06:42 PM
BILLETGRIP's Avatar
is it in gear or in neutral?
Old Aug 3, 2008 | 07:57 PM
its in neutral
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
VVV
Feb 16, 2007 02:36 AM
Eclpze97
Jun 9, 2004 12:16 PM
Gabe_
Dec 28, 2003 12:12 PM
baonest1
Nov 19, 2002 12:37 PM
