starts than dies?
Old Aug 2, 2008 | 01:43 PM
driftam1's Avatar
Default starts than dies?
just swaped the dohc zc into my 91 hatch it starts but it won't stay on unless i give it gas and hold it around 3k rpms How can i fix this? also no ecu codes?
Old Aug 2, 2008 | 01:50 PM
HonDelso's Avatar
bad injectors, or plugged up. are you using your old injectors? Si hatch, dx? need more info on the vehicle.
Old Aug 3, 2008 | 08:05 AM
driftam1's Avatar
Default Re: (HonDelso)
ok i have a code 4 crank position sensor and code 8 top dead center sensor how can i fix it?
Old Aug 3, 2008 | 03:10 PM
driftam1's Avatar
Default Re: (driftam1)
now i just have a code 8 top dead center how can i get the crank and head at top dead center ? take the timeing belt off?
Old Aug 4, 2008 | 07:36 AM
driftam1's Avatar
would a new dizzy solve this problem ? it starts but dosent stay running unless i give it gas so there is some spark but i keep getting a code 8 top dead center sensor
Old Aug 4, 2008 | 07:40 AM
D16SiHatch's Avatar
the top dead center sensor, or crank position sensor as it also goes by is located inside your distributor. so yes swapping it out may fix your troubles.
you may also find this helpful
http://media.honda.co.uk/car/o...2.pdf
Old Aug 4, 2008 | 08:54 AM
driftam1's Avatar
Default Re: (D16SiHatch)
if there was something wrong with my dizzy wouldnt the car not start?
Old Aug 4, 2008 | 10:22 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Is the car timed correctly? Could just be the sensor, or could actually be telling you you aren't at TDC.
Old Aug 4, 2008 | 11:42 AM
driftam1's Avatar
Default Re: (phoenix_iii)
i think its at top dead center i put the crank pull with the red line pointing up but i wasent to sure how to put the cam gears i put them up to but it still doesents seem to run right
pos94accord
Jan 25, 2009 05:29 PM
hondacrx2
May 9, 2007 10:43 AM
ham
Mar 7, 2007 08:26 AM
Anti-Drama Queens
Apr 11, 2006 03:58 PM
