no blinkers, tach, fuel, temp, clock need help ty
Old Aug 2, 2008 | 08:00 AM
andertom's Avatar
Default no blinkers, tach, fuel, temp, clock need help ty
I recently had an electrical problem on my 91 hatch where i lost my blinkers, tach, clock, fuel and temp gauges. I checked the fuse and it is good, just to make sure i put a new fuse in, also checked all the other fuses and all fine. my clock lights up if i press it and i do have hazzards. Any suggestions?
Old Aug 2, 2008 | 12:37 PM
tyler100's Avatar
Default Re: no blinkers, tach, fuel, temp, clock need help ty (andertom)
SAME PROBLEM IM HAVING> hope someone can get an answer. im on the 3rd day of tracing wires. i pulled my dash finally. anything you have done that might have done this?
tyler100's Avatar
Default Re: no blinkers, tach, fuel, temp, clock need help ty (tyler100)
but i dont have hazzards. and my clock dont work.
Old Aug 2, 2008 | 03:09 PM
oooblessooo's Avatar
i had this problem last week. i put in a crx si dash in my hatch about six months ago, i finally fired up my car last week and didn't have any dash lights or outside blinkers. so i pulled the dash and couldn't find anything until i saw something not plugged in on the steering column. it looks like its the door buzzer. i already had one plugged in some where else behind the dash, but when i switched them everything lit up. so i guess the first one was bad. i would check and see if either its not plugged in or the box is shot. i don't understand why this solved it but i don't really care now that my lights work. i hope this works for you
Old Aug 2, 2008 | 11:39 PM
tyler100's Avatar
Default Re: no blinkers, tach, fuel, temp, clock need help ty (oooblessooo)
looking tomorrow hope it works out for me like it did you. any pics of what im looking for?
Old Aug 3, 2008 | 07:37 AM
cant set up pics right now, im on trial. but it should be in the left side of the steering column. it is a small box with vent lines
Old Aug 3, 2008 | 11:39 AM
tyler100's Avatar
did it say AH20 on it? in white letters? you got a new one and everything worked fine?
Old Aug 3, 2008 | 04:21 PM
i think so.... the car is at my parents garage but i got to stop there tomorrow so ill check
Old Aug 3, 2008 | 05:24 PM
bodiez's Avatar
Hit the floor!
I had that same exact problem. There is a red plug underneath the dash that was loose. make sure that connection is connected. I had alllll the same symptoms as listed above and this was all it was.
JDM H22
Nov 5, 2007 02:43 PM
efking1985
Mar 9, 2007 06:04 PM
jdmhagengsr
Sep 24, 2006 09:30 AM
leprechan117
May 5, 2003 02:42 PM
