distributor question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m »</TD></TR><TR><TD CLASS="quote">Are all OBD1 d-series distributors the same?</TD></TR></TABLE>
Sorta, they all share the same electronics. But the D16Z6/D15Z1 distributors have a different mounting flange than the D15B7/D15B8 distributors. The DOHC OBD1 ZC distributors are the real oddball here, the electronics are the same but thats about it, they use a very different mounting flange, they have one really long foot, and while the shaft looks the same, the hole drilled in the end to lock the 2 pronged cam that goes into the camshaft is drilled about 90 degrees differently than every other d-series distributor. Basically swap electonics if a sensor is bad, and in the case of D15B7/B8 vs D16Z6/D15Z1 you can swap the shafts if the bearing goes bad. Hope that helps.
I am in the process of rebuilding my d16z6. i swapped a y8 head on it, but i put a bisimoto stage 2 cam in it that was meant for the z6. i have an adjustible cam gear for the z6 also. heres where my issue comes, the distributor doesnt fit, so i was going to buy a y8 distributor and wire it all up by hand. so i was just wondering if this will work? or what kind of problems i could run into with timing.
Meaning that buying a new distributor that already has the correct wiring (a D15B7/D15B8 one) is less work than having to rewire the plug(s) of the harness or of the distributor (a D16Y8 one).
dr_latino999
Jul 25, 2005 06:12 AM
