TrackSol Garage Sale: many spare parts, k&n, EG, EK, D16, H22, Bseries
Old Aug 1, 2008 | 11:11 PM
TrackSol's Avatar
Default TrackSol Garage Sale: many spare parts, k&n, EG, EK, D16, H22, Bseries
Ok, let's try this again.
I just moved and I need to clear out some of this stuff. Need the money to work on the del Sol.
All prices are negotiable and are without shipping costs. For the local guys, I'm in Enid, OK so I'm not driving to OKC or Tulsa for less than $50.
More stuff soon, still unpacking...
EM1 throttle cable SOLD
EM1 engine mounts SOLD
del Sol seat rails SOLD
D16Z6 dizzy SOLD
CONTACT INFO:
AIM: TrackSol
Yahoo: TrackSoler
Email: tracksol <at> gmail <dot> com
Cell: 407-353-one-three-nine-nine
CAR PARTS:
eg civic sedan bumper no cracks $50
del sol unfinished "patzbox" for 10" subs $25
del sol seats minor wear. $200
92-96 prelude h22 shifter and cables with all bolts and bushings $50
K&n filter #1 $20
K&n filter #2 $20
generic filter $10
h22a ignition coil $25
h22a alternator & bracket $75
h22 power steering pump and bracket $50
another h22 coil $25
h22 spark plug wires $15
h22 valve cover and oil cap $50
2000 Civic Si fuse box and harness $50
2000 Civic Si under dash fuse box $50
2000 Civic Si power steering reservoir $10
2000 Civic Si clutch master cylinder and resevoir $25
*perfect for an auto-manual swap
2000 Civic Si front LCA inside brackets $10
2000 Civic Si evaporator $25
2000 Civic Si fuel filter $20
2000 Civic Si pedal assembly $50
2000 Civic Si door garnishes $20
2000 Civic Si test pipe $25
2000 Civic Si aem cold air intake lower portion $20
2000 Civic Si a/c console with broken vent (super glue will work) $25
2000 Civic Si ac condensor with fan $50
2000 Civic Si brake booster and master cylinder $100
del sol winshield washer reservoir and pump $25
eg ground control coilovers (only front) on stock shocks $50
45* intake tube $10
eg camber kit $25
d16z6 starter $25
honda injector resistor boxes $10each, 2 for $15, 3 for $20
EF civic/crx momo steering wheel hub $20
d16z6 engine harness missing dizzy plug (wires and terminals still there) $50
del sol si brake booster and 13/16 master cylinder $50
integra brake booster with slight surface rust $10
ef civic sedan 15/16 brake master cylinder $50
*will bolt right on to any eg booster for a nice upgrade
clutch master cylinder reservoir $10
d16z6 spark plug wires $20
rota circuit 8/10 caps x2 $10
honda eg battery holder $5
eg a/c hose $5
s2000 antenna $10
eg civic fuel filter to rail hose $10
d16z6 obd1 camshaft (better than d16y8) $50
del sol b pillar garnishes previously painted $10
del sol d series shift linkage $50
*perfect for a del sol auto to manual swap
del sol passenger headlight $50
del sol driver side headlight #1 with slightly cracked mounting bracket $40
del sol driver side headlight #2 with slightly cracked mounting bracket $40
del sol corner lights $20 each or both for $30
eg civic instrument panel with tach$50
CAR AUDIO:
kenwood rc-517 remote $10
MISCELLANEOUS:
Vertical BMX bike needs innert tubes and brake pads $50
Modified by TrackSol at 1:38 AM 8/5/2008
Modified by TrackSol at 10:42 PM 8/5/2008
Old Aug 2, 2008 | 10:04 AM
TrackSol's Avatar
placed pictures in thread.
Modified by TrackSol at 3:10 PM 8/2/2008
Old Aug 2, 2008 | 11:12 AM
TrackSol's Avatar
bump
Old Aug 3, 2008 | 09:56 AM
TrackSol's Avatar
bump. help me finish my del sol....
Old Aug 3, 2008 | 10:26 AM
jaw0885's Avatar
this guy deserves my bump. how much for a just that one rear bracket off the bseries.
Old Aug 3, 2008 | 02:28 PM
TrackSol's Avatar
Default Re: (jaw0885)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaw0885 &raquo;</TD></TR><TR><TD CLASS="quote">this guy deserves my bump. how much for a just that one rear bracket off the bseries. </TD></TR></TABLE>
Thanks for the bump. 25 shipped for the rear bracket, however I've got a pending sale for all the mounts together. I'll let you know if the buyer flakes out.
Old Aug 3, 2008 | 03:36 PM
TrackSol's Avatar
@ jaw0885
Sorry, the buy purchased the whole lot.
Old Aug 4, 2008 | 09:34 PM
TrackSol's Avatar
BUMP! Stuff that was pending still for sale.
Old Aug 5, 2008 | 06:45 PM
TrackSol's Avatar
BUMP! Dizzy was sold, thanks!
Old Aug 15, 2008 | 05:18 PM
TrackSol's Avatar
Default Re: TrackSol Garage Sale: many spare parts, k&n, EG, EK, D16, H22, Bseries (TrackSol)
bump, need this stuff gone. have to by stuff for baby.
readyjetsgo
Apr 28, 2015 07:23 AM
JdmMik3
May 28, 2010 08:20 AM
TKL
Jul 24, 2003 12:10 PM
rflores2323
72
Nov 28, 2002 05:50 AM
