helpp, fuel pump problem!
Old Aug 1, 2008 | 10:59 PM
iheartjayDem's Avatar
Default helpp, fuel pump problem!
i have a 91 dx with a b18a swap and my fuel pump doesn't pick up fuel when theres about a 1/4 tank. the engine "runs out of gas" sputters and dies sometimes but only when Im around 1/4 tank. is there anyway the fuel pump can not be sitting right to not receive fuel when its low?
thanks
Old Aug 1, 2008 | 11:06 PM
1990EFHATCH's Avatar
Default Re: helpp, fuel pump problem! (iheartjayDem)
THATS THE SAME THING MY CAR DID WHEN I JUST HAD PUT IN MY JDM D15B VTEC BUT I JUST FILLED UP MY GAS THANK AND IT HASNT DONE IT NO MORE
Old Aug 1, 2008 | 11:07 PM
yeahh when i have a full tank or alot of gas she runs like a champ but when shes low is a different story=/
any ideas anyone?
Old Aug 1, 2008 | 11:31 PM
bump anyone?
Old Aug 2, 2008 | 09:50 AM
morning bumpp
Old Aug 2, 2008 | 02:54 PM
kenlrw39's Avatar
i just finished my swap and I'm having the same problem I add a gallon of gas and it ran fine then started to act up so added another gallon of gas and I'm sitting at the qaurter tank mark right now and it's running good I'm gonna look more into it and I'll post up what I find. What cluster are you running and do you know how much gas is in your tank could maybe be a bad calubrated cluster or something.
Old Aug 2, 2008 | 04:16 PM
1988_96hb's Avatar
Default Re: (kenlrw39)
my roomates 89 crx si does this too
Old Aug 3, 2008 | 12:37 AM
ahh! so many of the same problems. does anyone have answers!
Old Aug 3, 2008 | 10:33 AM
ttt
Old Aug 8, 2008 | 06:51 PM
JOE BD-0's Avatar
You guys should check to see if the fuel strainer "sock" is still attached to the pump inside the gas tank........good luck
Old Jan 28, 2015 | 06:15 AM
SCOTT1959's Avatar
thanks
but i never see my question in the threads?
thanks
Old Jan 28, 2015 | 06:39 AM
Malgerus's Avatar
This. Or it's in the right position but clogged up with gunk and/or rust. The only real solution is to order a new sock, drop the tank, inspect and replace if necessary.
91cb7h23
Feb 10, 2013 04:13 PM
dephtone
24
May 17, 2011 05:19 AM
EJ1B18c
28
Aug 24, 2010 08:19 PM
shawnperolis
Aug 20, 2010 06:49 PM
space-tuna
Jan 27, 2004 12:09 PM
