odo/trip not working
hey i was wondering if any of you guys would know why my odometer and trip isnt working? it just all of a sudden stop going... could it be loose wire behind cluster, a blown fuse, or something else?
my car is a 94 integra gsr with a b16a2 motor swap built with type r internals.
Does your speedo work too? If all three went out and with a CEL, you need to replace the VSS. Another issue might be with the circuit board behind the speedo mechanism.
where would the fuse for the cluster be located?
i checked and replaced all of the fuses in the fuse box under the hood and under the driver side kick panel.
is there even a fuse for it? help please...
Manolo
11
Sep 16, 2005 06:21 PM
TougeCoupe
May 18, 2005 05:12 PM
