zc obd 1 question
my buddy put an obd1 computer with a jumper harness and now the car cranks but wont start. and ideas or advice. the car runs with the obd0 computer. do ineed to swap pins or what??????
I had that problem on a swap I was working on. The jumper was bad so I ended up going through all the wires one by one with a wiring diagram that a friend had made. I don't really count on the jumpers much because of problem that buddies of mine had in the past but I still use them. Try to see if you can have someone look at the jumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullet eater »</TD></TR><TR><TD CLASS="quote"> If you are talking about the dohc ZC its not going to work because its a obd0 motor not a obd1!</TD></TR></TABLE>
Shut your mouth some came obd1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0_civic_4 »</TD></TR><TR><TD CLASS="quote">my buddy put an obd1 computer with a jumper harness and now the car cranks but wont start. and ideas or advice. the car runs with the obd0 computer. do ineed to swap pins or what??????</TD></TR></TABLE>
You might be better asking these guys for your solution for zc questions
http://www.thezcr.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0_civic_4 »</TD></TR><TR><TD CLASS="quote">my buddy put an obd1 computer with a jumper harness and now the car cranks but wont start. and ideas or advice. the car runs with the obd0 computer. do ineed to swap pins or what??????</TD></TR></TABLE>do you have an OBD1 TD43U distributor on it? - OBD1 ECU won't work with OBD0 distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">do you have an OBD1 TD43U distributor on it? - OBD1 ECU won't work with OBD0 distributor</TD></TR></TABLE>
bingo
bingo
9500redline
Aug 2, 2005 01:12 PM
