95 Civic EG oil problem
My civic is burning or leaking oil somewhere and i cant find the problem. Theres no oil on the ground but its slowly losing oil. My check oil light came on the other day and I checked the oil and there was none left, so i just added some more.
A friend in told me if it was burning oil that there would be colored smoke coming out the exhaust if its in neutral and I rev the engine, but the smoke is only a normal color.
How can i find out whats the problem?
The car is a 1995 Civic LX EG 96k miles
Modified by puma2132 at 8:20 PM 8/1/2008
well he said just a little black is normal when i rev it to like 4500 rpm cuz the engine is runnin rich from the rev.
but theres no smoke when its idleing.
i still have this problem too, after replacing the valve seals twice.
i thought it was my rings too, but we ran a compression test and leak down and the test came back negative.
You will also feel loss of torque. i'm just going to replace the motor then rebuild it.
I should not of used my CAI in the rain. Too much dirt in the throttle body.
Danieliyo
Jun 27, 2012 10:46 PM
gregv
11
Dec 23, 2005 02:08 PM
