F/S: Skunk2 Pro Series Stage 2 Cams $450shipped.
Old Aug 1, 2008 | 06:50 PM
b20_driven's Avatar
Default F/S: Skunk2 Pro Series Stage 2 Cams $450shipped.
SOLD!!!!
Modified by b20_driven at 5:45 PM 8/5/2008
Old Aug 1, 2008 | 07:49 PM
hrs-parker's Avatar
Default Re: F/S: Skunk2 Pro Series Stage 2 Cams $450shipped. (b20_driven)
dude..you just got those...gay!!! that [freak]ing guy is a [freak]ing [pejorative]
Old Aug 1, 2008 | 08:07 PM
b20_driven's Avatar
Default Re: F/S: Skunk2 Pro Series Stage 2 Cams $450shipped. (hrs-parker)
yeah, unfortunately i can't use them. How I washed I dont have oversized valves.
Old Aug 2, 2008 | 02:00 PM
KENetics1's Avatar
how do you know you can't use them, did you actually take the time to measure the v2v clearance? I've seen some setups on here that use them with os valves, they just measure to check for clearance and adjust cam timing properly. do you have +.5 or +1 mm os?
BearsEK uses os valves with pro3's
Old Aug 2, 2008 | 09:33 PM
b20_driven's Avatar
Default Re: F/S: Skunk2 Pro Series Stage 2 Cams $450shipped. (KENetics1)
I have 1mm oversized valves. =D I didn't even clay my motor. So its kinda risky. i already bent some valves on my turbosetup with the itr cams and oversized valves. I dont want that to happen again. I guess i'll have to degree the camgears properly.
Old Aug 2, 2008 | 09:35 PM
b20_driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">how do you know you can't use them, did you actually take the time to measure the v2v clearance? I've seen some setups on here that use them with os valves, they just measure to check for clearance and adjust cam timing properly. do you have +.5 or +1 mm os?
BearsEK uses os valves with pro3's</TD></TR></TABLE>
you serious? he uses +.5 or +1mm os? I have +mm os. That thing must be a BEAST!!!
i wanted to run the pro2's with my built itr head and stock refreshed c5 bottom end.
Old Aug 2, 2008 | 10:13 PM
b20_driven's Avatar
cant seem to find this BearsEK you are talking about
Old Aug 3, 2008 | 08:11 AM
hrs-parker's Avatar
https://honda-tech.com/zero...age=1
Old Aug 3, 2008 | 08:12 AM
hrs-parker's Avatar
http://www.hondamarketplace.co...17478
Old Aug 3, 2008 | 10:32 AM
b20_driven's Avatar
thanks, pete. looks like a beast. i can imagine shoua's car being a beast too. shiet
Old Aug 3, 2008 | 01:44 PM
SpoonSleeper's Avatar
What state are you located in? PM me if needed. I have a set of ITR cams, but they are in my DD right now.
Old Aug 3, 2008 | 01:51 PM
hrs-parker's Avatar
Default Re: F/S: Skunk2 Pro Series Stage 2 Cams $450shipped. (SpoonSleeper)
WISCONSIN
Old Aug 5, 2008 | 08:38 AM
pArAdOxsqUArE's Avatar
wish you were in the west coast.... [killa cali] bump.. GL with the trade/sale
Old Aug 5, 2008 | 10:50 AM
Dev15Bizz's Avatar
Default Re: F/S: Skunk2 Pro Series Stage 2 Cams $450shipped. (pArAdOxsqUArE)
call king motorsports in new berlin wisconsin, thats where bear works
he built mine im running pro 2s but stock size valves
Old Aug 5, 2008 | 01:12 PM
b20_driven's Avatar
SOLD SOLD SOLD
Civic-eg
12
Jun 21, 2013 02:20 AM
b20_driven
Aug 10, 2008 01:45 PM
b20_driven
Aug 2, 2008 09:38 PM
isaacprl
17
Feb 6, 2008 10:30 AM
Sl0wEK
Jan 15, 2007 08:53 AM
