del sol with gsr front brakes ball joint broke
Old Aug 1, 2008 | 06:31 PM
delVTECsol's Avatar
Default del sol with gsr front brakes ball joint broke
the lower ball joint on my del sol broke. the car has a gsr front brake conversion. in my driveway i have a 95 civic ex. will the front hub part with the lower ball joint work on my del sol? will i just have to use the gsr caliper and rotor?? thank you ahead of time and sorry if this is confusing im just really stressed that this happened!!!!!
Old Aug 1, 2008 | 07:12 PM
BlueIntegraBoy's Avatar
Default Re: del sol with gsr front brakes ball joint broke (delVTECsol)
You can use the EX knuckle and put the Integra caliper on it. EX and Integra rotors are the same.
Old Aug 1, 2008 | 07:59 PM
delVTECsol's Avatar
Default Re: del sol with gsr front brakes ball joint broke (BlueIntegraBoy)
thank you sooo much...i just wanted to make sure before i wake up early and start tearing into this!!!!!!!!!
SlowB16
Suspension & Brakes
Jan 16, 2013 02:04 AM
worx
May 22, 2010 05:00 PM
Black_Sol
Sep 3, 2007 06:44 AM
tylonalsnifnfool
Mar 23, 2006 07:50 PM
