hub, quick release, steering wheel= no horn???
Old Aug 1, 2008 | 11:09 AM
san_diego_DC's Avatar
Default hub, quick release, steering wheel= no horn???
so i just put and nrg complete set up in my dc and when i was complete. there was no horn... the hub that connects to the car had horn wires that connect to the quick release but no wires or connections of a power source to the car. can someone explain how to get the horn working with the aftermarket wheel????
Old Aug 1, 2008 | 05:47 PM
Richard...'s Avatar
Default Re: hub, quick release, steering wheel= no horn??? (san_diego_DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by san_diego_DC &raquo;</TD></TR><TR><TD CLASS="quote">so i just put and nrg complete set up in my dc and when i was complete. there was no horn... the hub that connects to the car had horn wires that connect to the quick release but no wires or connections of a power source to the car. can someone explain how to get the horn working with the aftermarket wheel???? </TD></TR></TABLE>
I found rather then messing with that head ache i simple wired a switch to the horn very simple and works gets a little getting used to but works all the same!
Old Aug 6, 2008 | 02:55 PM
EJ8chu's Avatar
Default Re: hub, quick release, steering wheel= no horn??? (Richard...)
Its very easy
http://weaksauceforums.org/viewtopic.php?t=2549
Old Aug 6, 2008 | 04:01 PM
bongpangi's Avatar
there should be a wire there post a pic....
Old Aug 6, 2008 | 08:21 PM
EJ8chu's Avatar
Summary of above posted link:
1. Run wire from plug where the horn wire is connected to some type of metal object(i used a paper clip)
2. Mount metal object where the clock spring was making sure it will make contact with the metal disc on the back of the hub
3. Place hub on and check to make sure contact is made.
4. Follow the rest of the installation instructions and test it out!
vtec69
31
Feb 24, 2012 06:36 AM
ThatGuy4life
Aug 20, 2007 08:05 PM
ayougo
Jul 17, 2006 11:07 AM
Conechaser
Nov 27, 2002 09:11 AM
