Wheel stud replacement/ hub modification question
Old Aug 1, 2008 | 10:15 AM
_Keith_'s Avatar
Default Wheel stud replacement/ hub modification question
Ok on our years we dont have the little notch like the DC's do to remove the studs easily.
So how bad is it if I make that little groove to remove and install the studs easily?
I did a search and it seems like people are going back and forth. Im about to put some new studs in because when I bought the car couple were messed up in the front.
Thanks
Old Aug 1, 2008 | 10:43 AM
slywfbpsi's Avatar
Default Re: Wheel stud replacement/ hub modification question (_Keith_)
http://fourthgenhatch.net/wheelstud.html
Old Aug 1, 2008 | 10:44 AM
_Keith_'s Avatar
Default Re: Wheel stud replacement/ hub modification question (slywfbpsi)
Um no I wont do that...
That ruins my stud...
Im wondering about grinding the hub... to have a small spot like the DC's come with stock.
Old Aug 1, 2008 | 12:16 PM
JesseCRX's Avatar
Just grid the hub. It's not much metal, and it's pretty soft too. I used a dremmel with regular low grit sandpaper heads to grid mine down. Worked perfectly. No cutting on the stud either.
cmfnelson
Nov 24, 2012 01:03 AM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
stealth_EK4
Honda Civic (2001 - 2005)
Apr 11, 2008 08:23 PM
dre2day
Feb 16, 2008 07:56 AM
RTW DC2R
Feb 13, 2006 08:21 PM
