gsr motor bild up
Old Aug 1, 2008 | 10:11 AM
JDMDC2899's Avatar
Default gsr motor bild up
i have a 95 stock gsr high miles. i want to know the best combo to rebulid my motor like cam and piston combos, valvetrain combos. i want a mild build that will still pass smog. any suggestions?
Old Aug 1, 2008 | 10:15 AM
Horseofcourse's Avatar
Default Re: gsr motor bild up (JDMDC2899)
Type R Everything..... Its better than GSR stuff. Slightly More Aggressive Cams. And go with a nice name brand set of springs and retainers.
This is a pretty mild build. Isnt going to cost you a fortune. and you will see some noticeable power gains.
81.25 bore and use Honda Factory parts for everything you can. Get new pistons if you can. Cams you can buy used on here all day. All TYPE R or CTR
Old Aug 1, 2008 | 10:59 AM
MTVtec's Avatar
Default Re: gsr motor bild up (Horseofcourse)
Deffinately upgrade your Intake mani, the snail shell on the GSR is crap in comparison to the ITR style. Also itr pistons and cams are an affordable seat of the pants gain in HP. GL with the build
Old Aug 1, 2008 | 02:50 PM
Dark@Powers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Horseofcourse &raquo;</TD></TR><TR><TD CLASS="quote">This is a pretty mild build. Isnt going to cost you a fortune. and you will see some noticeable power gains.</TD></TR></TABLE>
If he is going to rebuild the whole motor then it is going to get damn pricey.
Have you considered just building the head? It will be much cheaper and you will some some great gains, without the bother of having the touch the block.
Old Aug 1, 2008 | 06:04 PM
well since it has high miles he is prolly looking to replace the rings and bearings. To make it a daily driver and not have to pull the motor after he pops a bad ring because he is raising the compression with a more aggressive head. Just take the motor out and do it all at once. do it right.
Old Aug 1, 2008 | 09:00 PM
Jintegragsr97's Avatar
I got a ctr intake cam and Brand new ITR valve springs FS Will go perfectly with your head and still pass smog
Old Aug 1, 2008 | 10:32 PM
racebum's Avatar
Default Re: gsr motor bild up (Jintegragsr97)
i'm looking into just getting the full type r swap for $3900, we can sell our GSR stuff to make up some of the cost and you get a low mile full on type r everything.
Old Aug 2, 2008 | 12:34 AM
Big Props to the guy from my home state!!! Go Ducks!
Anyway. Save the extra money on suspension, brakes, wheels and tires maybe some body work. Things that will make a difference. If you rebuild your motor like I listed. It will last you prolly 200k miles. and you will know what you have in it. it will have your time, your sweat, and your money in it, It will have that pep in the step. All your vins will match smog will pass no problem. If you swap the type r. Things dont match and in California they do care about stuff matching and being Legal. Where as here in oregon in most parts you dont even have to get the car inspected or DEQ/Smog tested.
Old Aug 8, 2008 | 11:51 PM
JDMDC2899's Avatar
Default Re: gsr motor bild up (MTVtec)
thats what i was thinking i wanted to do a build from thr crank up and itr cams and a builtproof head any good combos?
exotik4doorcivic
Feb 18, 2008 06:52 PM
IOWAb16TEG
Aug 11, 2007 10:57 PM
integraLB1S
Apr 8, 2007 12:28 PM
VTECth1s
Jun 14, 2006 07:07 AM
ek9tl
May 27, 2006 06:42 PM
