squeaking.
ok my car used to ride fine until one day my, i guess rear suspension, began to squeak. like every little hump or bump in the road causes this annoying sound. like my music can block it out but i dont like banging all day lol
what can this be? or how can i go about fixing it?
You could try spraying some whit lith on all the bushings, trailing arm, control arm, links, strut, and letting it soak in for a little then wipe the excess off then put another lin layer on and this will condition them a bit and if it these that are squeaking it might fix the problem
I dunno if that would be a blown shock it might be something other than that but i would be sure to make sure you bounce the car up and down and find out where the squeak is coming from because if you layer it it might now turn out right.
tatmark1
Oct 10, 2007 03:13 PM
yh23
10
May 31, 2005 05:11 PM
yellowturbo
Mar 25, 2005 10:45 AM
