MAIN RELAY HELP!
Old Aug 1, 2008 | 09:32 AM
whiteformula98's Avatar
Default MAIN RELAY HELP!
Everyone is saying that my main relay is the reason i am throwing the 16 flashes code on my 1990 honda hatch.... How do i fix this or do i buy a new one?
Old Aug 1, 2008 | 10:11 AM
bodiez's Avatar
Hit the floor!
Default Re: MAIN RELAY HELP! (whiteformula98)
Buy a new one. $60 at autozone. Its right infront of and up from the hood latch. Take off the 10mm bolt, and drop the relay down, then put the new one on, and voila
Old Aug 1, 2008 | 10:32 AM
some say location is under the dash and some say engine bay...which is it? any pics?
Old Aug 1, 2008 | 10:54 AM
jdm27ef's Avatar
Default Re: (whiteformula98)
its by the latch of the hood you will see it there. its hard to get it out thought thats the challenge!
Old Aug 1, 2008 | 11:10 AM
neozero999's Avatar
Default Re: (jdm27ef)
you can always go to the junkyard look for a 88-91 civic/crx and get its main relay
Old Aug 1, 2008 | 11:19 AM
Found it, its not by the latch of the hood, its under the dash left of steering column
Old Aug 1, 2008 | 11:21 AM
semi close to hood latch id say but not under the hood like some people think...thanks guys
Old Aug 1, 2008 | 11:23 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteformula98 &raquo;</TD></TR><TR><TD CLASS="quote">semi close to hood latch id say but not under the hood like some people think...thanks guys</TD></TR></TABLE>
correct. under the hood is the main engine "fuse".
Old Aug 1, 2008 | 12:43 PM
traxxasx's Avatar
Why buy a new one for 60$?
[freak] that.
pop out the relay and just add some solder to all the solder points on the relay.
Fixed and good to last another 18 years.
Old Aug 1, 2008 | 01:00 PM
2ed6sbandzc's Avatar
Default Re: (traxxasx)
+1
Old Aug 1, 2008 | 06:01 PM
beige89civic's Avatar
* B A N N E D *
39400-SH3-003. There's your part number. Buy a Honda one and be done with it.
Old Aug 1, 2008 | 06:48 PM
rockcity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">Why buy a new one for 60$?
[freak] that.
Fixed and good to last another 18 years.</TD></TR></TABLE>
Agreed. Just had this problem yesterday. Bought a soldering iron and now I am good to go.
Old Aug 1, 2008 | 07:32 PM
Aristotle's Avatar
You can use one from a 92-95 Civic or OBD1 Integra and there all located in the same place.
Old Aug 1, 2008 | 07:51 PM
i have never soldered before so whyy cant i just buy one from adavance auto parts..whats the big deal?
Old Aug 1, 2008 | 09:12 PM
GLI's Avatar
GLI
Soldering is a good skill to learn so why not use that money to buy gas?
Old Aug 1, 2008 | 11:13 PM
nicholasmak's Avatar
Default Re: (GLI)
http://www.google.ca/search?hl...&meta=
its easy man, and like the guy above said, its a good skill to learn! plus it will save you some monies
Old Aug 2, 2008 | 01:31 AM
traxxasx's Avatar
All you do is let the iron heat up, touch some solder to the tip if it melts your good to go.
Place the iron on one of the soldering contact point until the solder melts, then with your new solder while still holding the iron on the point push the new solder into the melted solder till its nice and built up then remove iron and let it dry which will take a couple seconds.
Its very easy and the kit is like 10$ at walmart or radio shack.
Old Aug 2, 2008 | 06:03 AM
wat exactly am i soldering though...that is what is confusing me? ne pics?
Old Aug 2, 2008 | 08:53 AM
ttt....
Old Aug 2, 2008 | 01:45 PM
traxxasx's Avatar
Take the relay out of the car.
Pop the plastic cover off the relay, then you will see many silver contact point.
Just resolder them all.
Dont connect any of them together.
All your doing is making the solder solid again from hair line cracks.
Old Aug 2, 2008 | 03:05 PM
GLI's Avatar
GLI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteformula98 &raquo;</TD></TR><TR><TD CLASS="quote">wat exactly am i soldering though...that is what is confusing me? ne pics?</TD></TR></TABLE>
Here
you solder those and here is another picture
and heres the link
http://www.tegger.com/hondafaq....html
Old Aug 2, 2008 | 03:55 PM
Slystone's Avatar
so easy to fix!!
fitbkeco
10
Mar 20, 2013 02:34 AM
bestcivic
Aug 12, 2009 05:17 PM
90crxdxb16
26
Nov 9, 2006 07:31 AM
Tuner Eddy
Sep 13, 2005 08:57 PM
Z6REX-SI
12
Jan 6, 2004 04:17 PM
