gsr swap for 2 weeks, no vtec =[
Old Aug 1, 2008 | 09:13 AM
Ryan97's Avatar
Default gsr swap for 2 weeks, no vtec =[
i just recently did a gsr swap in my 1997 honda civic dx. i am running an obd1 gsr with and obd1 gsr ecu. i used my stock dx harness(wired up knock, vtec and pressure switch) and then used a rywire jumper harness(obd2a-obd1). The car starts up and runs perfect, doesnt burn any oil, but vtec doesnt kick. Im running a primary o2 code.i replaced the o2 sensor disconected the battery and ran the codes again and still have the code. i dont know if the code has anything to do with my vtec not kicking in but i figured i would give as much information as i can. I have oil so its not the oil pressure, its all wired to the right spots(checked many times)the solenoid is plugged in, pressure switch is plugged in,everything should be up and ready to go..
please if you could give me any information or if i missed a link when i was searching(before i made this post) that would be greatly appreciated.
having a gsr without vtec is like having a house with nothing in it.
Old Aug 1, 2008 | 09:16 AM
OMGWTFBBQ!'s Avatar
No 02 sensor = no VTEC. Check the voltage on the 02 sensor with a multi meter.
Old Aug 1, 2008 | 09:23 AM
Ryan97's Avatar
Default Re: (OMGWTFBBQ!)
thats what i thought and then i went and jacked my friends car and unplugged the o2 sensor and his kicked. is it different for jdm?hes running a jdm ecu. but thanks for the info
Old Aug 1, 2008 | 09:24 AM
Hanmin's Avatar
lol. i learn something new everyday, no o2=no vtec. is that code the only code your getting? I forget, does the dx have the 4 wire or the 5 wire? or the 1 wire? if it doesnt have the 4 wire o2 then you need a new harness, try getting your hands on a gsr harness. thats only if your o2 sensor isnt the 4 wire one=].
Old Aug 1, 2008 | 10:45 AM
Ryan97's Avatar
Default Re: (Hanmin)
i think i have the 4 wire.
Old Aug 2, 2008 | 01:29 PM
Ryan97's Avatar
Default Re: (Ryan97)
Old Aug 3, 2008 | 10:54 PM
Ryan97's Avatar
fixed my o2 problem and currently have no CEL's but still no vtec
phoxking
Mar 12, 2011 10:04 AM
0ldsk00lef
41
Aug 30, 2010 09:38 AM
91EF_Si
Feb 19, 2008 09:11 AM
white90rexsi
25
Jul 25, 2007 02:55 PM
got wide
Apr 3, 2007 04:57 PM
