Will a 99-00 Si VSS work on a 96 JDM ITR swap
I need to replace my speed sensor on my jdm ITR thats in my 94 civic hatchback. I havent had luck buying a used VSS before so I want to buy new. Will only the b-series 94 and up integra VSS work or would a VSS from a 99-00 Civic Si also work?Also where is the best place to buy a new speed sensor?
Thanks
Thanks
All 94-01 Integra and 92-00 Civic VSS are interchangeable with each other, regardless of d/b-series and design. Make sure you get MT VSS for MT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHhonda99 »</TD></TR><TR><TD CLASS="quote">the one out of my 94 ls is different from one out of a 99 civic si... the ls even bolts on with 2 bolts instead of only one like the civic</TD></TR></TABLE>
The sensor itself to the gear rod is two bolts, but only requires one bolt to mount to the tranny.
B/D-series have the same plug.
yea, but isn't the sensor its self different. I know it has the same top plug on it, but the civic SI one is really long, with a gear on it any everything, and my ls was short and way different.
Civic SI vs Integra LS:
hulk252
Mar 5, 2006 03:13 PM
hondacivichatch
Sep 30, 2005 09:46 PM
Street Ghost
Jun 11, 2003 07:13 PM
