Can anyone help me out...
Old Aug 1, 2008 | 06:31 AM
suthernbred904's Avatar
Default Can anyone help me out...
I have a 99'ek w/98'ls in it. my problem is that my ls ecu is having problems running with it. so i have my p2E cx ecu running my ls,and its running real rich and im spending way too much on gas! so when i put my ls ecu in it used to crank right over but would turn off with any sudden move to the ecu,now it would crank and maybe run for a min. and bog down than shut off. any ideas..would greatly appreciate it. thanks
Old Aug 1, 2008 | 06:35 AM
Syndacate's Avatar
Default Re: Can anyone help me out... (suthernbred904)
The P2E is a DX ECU, which is a D16Y7, a relatively small, very fuel efficient engine.
If it's running rich there, there's a problem, if anything it should run lean there. It has about the same redline as an LS, but the LS def. requires more fuel.
Do you have the OEM fuel components, or are you running a different FPR or fuel pump or something?
Old Aug 1, 2008 | 06:50 AM
still oem fuel comp.,stock fuel pump..my car is eating gas fast,no leaks
Old Aug 3, 2008 | 01:36 PM
any one have an idea?
s032105k
11
Apr 14, 2011 08:01 PM
SiRk
Nov 8, 2005 05:52 AM
redlseg
12
Aug 12, 2005 04:44 AM
jmcfkya
Aug 27, 2003 12:39 PM
96tegra
Jul 1, 2003 06:38 PM
