starter problems! need ur help **searched**
Old Jul 31, 2008 | 07:31 PM
dirtyharryhatch's Avatar
A Digital Frontier
Default starter problems! need ur help **searched**
ok so this is the story i was on the way to little ceasars (yum!) to get pizza i was jamming out and stuff i turned off my car then i got the pizza when i went back outside i got in the car turned the key and nothing happened?! no clicking nothing so i was forced to push start it and it starts right up a friend told me its the wiring on the started that i have to bridge somethign to the key but that sounds kinda rigged i wana know the proper way of getting rid of this problem
any help will be greatly appreciated
Old Jul 31, 2008 | 07:50 PM
D16SiHatch's Avatar
Default Re: starter problems! need ur help **searched** (dirtyharryhatch)
well its either your main fuel relay, or perhaps the connections on your battery are loose.
Old Jul 31, 2008 | 08:01 PM
A Digital Frontier
i dont think its my fuel relay because my buddy had this problem on his coupe and he changed the relay and it still did the same thing. and the connections on my battery are fine cause my radio and everything electrical are functional. why would u think its the fuel relay though?
Old Jul 31, 2008 | 08:35 PM
D16SiHatch's Avatar
Default Re: (dirtyharryhatch)
hmm now that i think about it if your main relay was shortin out your car would still crank, it just wouldn't start. you're sayin that your not getting it to crank. When you turn it to run does the car go through the prestart crap (oil pressure, check engine light, etc come on, and then go off) ? When you turn it to on you should also hear the relay click, and then hear the fuel pump whirring away in the back of your car. Since it seems that your starter is not even engaging thats what lead me to suggest the battery terminals were loose. i know they've came loose on my car on occasion, and when i go back out to start the car i get nothing. and sure enough it was the battery cable that had loosened up. If its not at the battery that your getting a break in the connection, i would try looking over your fuse panel for anything that seems out of the ordinary. And then check all the connections going to your starter. You shouldn't have to "bridge" or ghetto-rig anything for your starter to function properly.
Old Jul 31, 2008 | 08:52 PM
pandarex's Avatar
Default Re: (D16SiHatch)
theres a lil button on the top of the clutch arm. sometimes that lil button breaks and causes the car to not start at all. no clicking, blah, blah. reach up to the top of the clutch and try to press the button and start the car. most likely your problem since it happened with no warning and starts right back up. happened to two of my ef's
Old Jul 31, 2008 | 09:07 PM
A Digital Frontier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">hmm now that i think about it if your main relay was shortin out your car would still crank, it just wouldn't start. you're sayin that your not getting it to crank. When you turn it to run does the car go through the prestart crap (oil pressure, check engine light, etc come on, and then go off) ? When you turn it to on you should also hear the relay click, and then hear the fuel pump whirring away in the back of your car. Since it seems that your starter is not even engaging thats what lead me to suggest the battery terminals were loose. i know they've came loose on my car on occasion, and when i go back out to start the car i get nothing. and sure enough it was the battery cable that had loosened up. If its not at the battery that your getting a break in the connection, i would try looking over your fuse panel for anything that seems out of the ordinary. And then check all the connections going to your starter. You shouldn't have to "bridge" or ghetto-rig anything for your starter to function properly.</TD></TR></TABLE>
ima check the fuses tommorow ima look over everything asap but yes the check engine light the oil light go on and then off and when i go to turn it on nothing happeneds no clicking nothing.
Old Jul 31, 2008 | 09:08 PM
A Digital Frontier
Default Re: (pandarex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pandarex &raquo;</TD></TR><TR><TD CLASS="quote">theres a lil button on the top of the clutch arm. sometimes that lil button breaks and causes the car to not start at all. no clicking, blah, blah. reach up to the top of the clutch and try to press the button and start the car. most likely your problem since it happened with no warning and starts right back up. happened to two of my ef's</TD></TR></TABLE>
me and my friend checked that out and he says it looks fine but ima go over all this tommorow thanx
Old Aug 1, 2008 | 04:31 PM
lowerthanu's Avatar
My ignition is having a problem similar to what D16YHATCH was saying, my cluster doesn't light up and the windows don't work when the key is in position 2, but when the key is BARELY into position 3, it all lights up and windows work fine. But if I put it in position 3 all the way to start it, it doesn't hold power for more than like half a second, any suggestions?
Old Aug 1, 2008 | 04:40 PM
lowerthanu's Avatar
Default Re: (lowerthanu)
anyone?
Old Aug 1, 2008 | 07:29 PM
GLI's Avatar
GLI
Starter ground wire came off?
Old Aug 1, 2008 | 07:45 PM
A Digital Frontier
ima go get a starter at the upick cause from what i hear the autoparts rebuilt ones are 90 and they last like for a week. so ima get one from the junk since there the oem ones
Old Aug 1, 2008 | 07:46 PM
A Digital Frontier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowerthanu &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
and try cleaning the battery terminals maybe that will help
Naiyasin
Dec 12, 2010 07:21 PM
kacivic
Sep 23, 2008 11:44 AM
keviiinnnnn
Jan 2, 2008 07:27 PM
dc4pos
Oct 13, 2006 08:29 PM
junkyardRx
15
Apr 26, 2004 03:04 AM
