Turbo for a 3.0 v6 Mr2, WARNING NOT A HONDA
Old Jul 31, 2008 | 07:26 PM
Sketch_hs's Avatar
Default Turbo for a 3.0 v6 Mr2, WARNING NOT A HONDA
So i've decided on boosting my recently completed 3.0 3vzfe V6 mr2
I was wondering what input you guys could give for what turbo to use.
Goals:
1. CHEAP
2. 260-300whp/tq
3. hardly any lag (full boost before 2500rpms, power up to stock redline 6850)
Turbo will be mounted in the trunk most likely, using a small intercooler if possible
Had a gt28rs w/ .82 hotside on a 1.9 built GSR civic in the past, liked it but would like a little more response...
Have a big T4 on the supra, love the power but hate the lag (weekend car with gt30 in its future)
The mr2 is the daily so i want to do this cheaply and make a really great street car...
okay hit me
Old Jul 31, 2008 | 07:58 PM
omiehomie's Avatar
Default Re: Turbo for a 3.0 v6 Mr2, WARNING NOT A HONDA (Sketch_hs)
words of wisdom from a former MR2 owner, you want cheap, fast, and reliable.
those three words do not go together in the same sentence, pick two...
if you want it cheap and fast its not going to be reliable.
if you want it fast and reliable its not going to be cheap.
if you want it cheap and reliable its not going to be fast
get where im going
Old Jul 31, 2008 | 08:18 PM
Sketch_hs's Avatar
i mean a cheap turbo, not some awesome BB GT30R (money goes to the supra) Something used ... cheap OEM but effective etc...
not going to cheap out on the tuning or fuel system stuff (duhhh)
Old Aug 1, 2008 | 02:15 PM
Sketch_hs's Avatar
Old Aug 1, 2008 | 02:42 PM
levee000's Avatar
id go with a 50 trim for it
Old Aug 1, 2008 | 04:47 PM
quicksilver1689's Avatar
i ♥ snails
yeah a 50 trim with the large housings for some v-6 flow
Old Aug 1, 2008 | 08:44 PM
omiehomie's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">i mean a cheap turbo, not some awesome BB GT30R (money goes to the supra) Something used ... cheap OEM but effective etc...
not going to cheap out on the tuning or fuel system stuff (duhhh)</TD></TR></TABLE>
hit up spoolin performance in the hondatech market place, im sure he could make you a nice manifold and downpipe for you application that wont decimate the pocket book
Old Aug 1, 2008 | 10:29 PM
Sketch_hs's Avatar
Default Re: (omiehomie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omiehomie &raquo;</TD></TR><TR><TD CLASS="quote">
hit up spoolin performance in the hondatech market place, im sure he could make you a nice manifold and downpipe for you application that wont decimate the pocket book </TD></TR></TABLE>
i'm going to make all my own piping/exhaust etc...
just trying to figure out what actual turbo to use
Old Aug 1, 2008 | 11:06 PM
DC-2uned's Avatar
Default Re: (Sketch_hs)
HONDA-tech.com, try mr2oc.com or toyotanation.com. Not to be a d!ck but we have enough "what turbo should I use for my b16/18, h22, f22, etc. setup" that adding other makes is just annoying and irrelevant.
Old Aug 2, 2008 | 06:20 AM
HiProfile's Avatar
Default Re: (DC-2uned)
Actually asking at a different site can sometimes be helpful. It keeps the retards that simply repeat popular info from wasting the OP's time.
Look at overall WHP goals, then look at what certain turbos can do. I'll assume it isn't 'built' - doesn't have aftermarket forged rods/pistons. 250-300whp would be attainable with a gt28rs or a 50trim t3/t04e at 15psi or so, or you could do it the right way - build a divided manifold, get a GT32 ($750), then have a broader power band and still be capible of almost 400whp. That turbo would get you everything you want - price, power, and less lag. FYI its turbine and compressor flow a bit less than a larger GT30. Just understand that it usually takes a lot of work & planning to get 4k rpm worth of powerband out of most motors.
Old Aug 2, 2008 | 06:29 AM
Sketch_hs's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Actually asking at a different site can sometimes be helpful. It keeps the retards that simply repeat popular info from wasting the OP's time.
Look at overall WHP goals, then look at what certain turbos can do. I'll assume it isn't 'built' - doesn't have aftermarket forged rods/pistons. 250-300whp would be attainable with a gt28rs or a 50trim t3/t04e at 15psi or so, or you could do it the right way - build a divided manifold, get a GT32 ($750), then have a broader power band and still be capible of almost 400whp. That turbo would get you everything you want - price, power, and less lag. FYI its turbine and compressor flow a bit less than a larger GT30. Just understand that it usually takes a lot of work & planning to get 4k rpm worth of powerband out of most motors.</TD></TR></TABLE>
thank you
Old Aug 2, 2008 | 06:47 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">Have a big T4 on the supra, love the power but hate the lag (weekend car with gt30 in its future)</TD></TR></TABLE>
Ok this might be a stretch but how about you use your old Supra turbos???? Perfectly sized for a 3.0L too
Old Aug 2, 2008 | 01:20 PM
Rob03Pro5's Avatar
50trim with a .82 A/R
Really quick spool for that motor.
Old Aug 2, 2008 | 09:05 PM
Sketch_hs's Avatar
Default Re: Turbo for a 3.0 v6 Mr2, WARNING NOT A HONDA (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">
Ok this might be a stretch but how about you use your old Supra turbos???? Perfectly sized for a 3.0L too</TD></TR></TABLE>
doing a twin setup would be to complicated... thought about it though
67mmlsv
Oct 18, 2012 09:29 PM
R_Pizz3l
May 8, 2012 02:46 PM
Lamska
May 29, 2006 11:20 AM
vadersi
Feb 16, 2005 05:04 PM
xstalkrx
Jun 27, 2004 03:37 PM
