no a/c!!!
hey you guys im back again with another problem....i finaly did the h swap and ever since i got it done my a/c doesnt work and both of my rad fans stay on constantly i got my volt meter and there is no current going to the 1 wire plug that goes to the a/c compressor
if i give it 12v it turns on but as we all know you cant have the compressor on for to long or your a/c lines will freeze so what could be the problem?
do you have good ground from the red/white wire at the pressure switch?
I had a problem with the ground coming from the A/C thermostat to the pressure switch. Manually grounding the red/white at the pressure switch made the system work and confirmed there was no ground from the thermostat. I replaced the thermostat and it all worked.
dude im worried about this with my swap seriously....what A/C bracket did you use? F or H?....i've spent nearly $300 bucks on a brand new a/c system and I'm loving it and dont wanna lose it after the swap.
im pretty sure i used the same bracket... lol dont remember but if the f bracket doesnt work just make it work i made my f22 powersteering bracket work on my h22 i just had to make new holes add longer bolts and a shitload a washers works perfectly
and what ground are you talking about bro that red wire that connectes to the a/c compressor isnt connected to ground is it?
homermeza
Apr 18, 2017 06:51 AM
